irule execution sequence
I have two tests to perform. If the first rule is enacted, I don’t want the second one to happen - how do I order the rules or combine them to make sure they both don’t apply to the same request?
rule portal-8080 {
if { [HTTP::host] eq “portal.com” } {
pool portal.8080-only
pool poolb
rule http2https
when HTTP_REQUEST { HTTP::redirect https://[HTTP::header host][HTTP::uri]}
virtual hpssopro_80 {
destination 10.10.10.15:http
rules portal-8080  http2https
there are a couple of options. first is to use event disable command. event   event second is to set variable in one event/irule and then check it in another event/irule (to decide whether event/irule will be executed or not).
helpful article regarding iRule Stacking:
Stacking iRules: A Modular Approach https://devcentral.f5.com/articles/stacking-irules-a-modular-approach
I did read that one…but thanks anyway
I did check out both those. Basically, if the fqdn matches, I don’t want the http-to-https redirect to happen- just looking for confirmation that this is what that does. I don’t have a test device to try it out on.
thanks
oh wait - will this one do what I want above?
b rule portal-8080-redirect ‘{ when HTTP_REQUEST { if { [HTTP::host] eq “portal..us” } { pool portal-8080-only } else { when HTTP_REQUEST { HTTP::redirect https://[HTTP::header host][HTTP::uri]} } } }’
remove the second “when HTTP_REQUEST”, and i think it will do what you are looking for
and change from HTTP::redirect https://[HTTP::header host][HTTP::uri] to HTTP::redirect https://[HTTP::host][HTTP::uri]
thank you all - this makes perfect sense now.
so I got a chance to test, and it doesn’t work - I put in a log local0, and see that the HTTP::host is exactly what I am expecting, but the pool selection doesn’t trigger. What other ideas do you all have?
b rule portal-8080-redirect ‘{ when HTTP_REQUEST { if { [HTTP::host] eq “portal.somestate.us” } { pool portal-8080-only } else { HTTP::redirect https://[HTTP::host][HTTP::uri] }}}’
how do you know? have you checked tcpdump?
this would be one of those “duh” moments…the pool was down!! So I got the rule working, and thank all of you for you help on this one!
