I have list of IP addresses in Data group called “BlackListIP” and it defined as “String” type instead of “Address” like
"name": "1.1.1.1, 2.2.2.2, 3.3.3.3, 4.4.4.4, 5.5.5.5, 6.6.6.6"
And I have iRule that use for lookup the Client IP address and need to be block if it matched IP address list above
when CLIENT_ACCEPTED { if { [class match [IP::client_addr] contains BlackListIP ] } { reject } }
Let say, right now my client_addr equal to 1.1.1.1, Logically it should work, but after test it out this particular iRule doesn’t work as expect. Anything I missed here. Please shed some light.
Thanks,
Logically, your iRule looks ok, try adding logging to see what IP address you connection is coming in on: However you have not included a
when
at the start of the event - this may be the cause of your problem.
log local0. "IP: [IP::client_addr]"
if {[class match [IP::client_addr] contains BlackListIP] } {
reject
Try splitting the client ip address on the %. The address has a % at the end. That might cause the lookup failure. Also, I used equals instead of contains. Hope this helps.
set client_ip [getfield [IP::client_addr] "%" 1]
if { [class match $client_ip equals BlackListIP ] } {
reject
Also, please have a look at Kai Wilke’s answer in this thread : https://devcentral.f5.com/questions?pid=48727. He did a great job helping me with a related question.
