insert field to HTTP header
can BIG-IP insert field data into the HTTP header that the IIS server can then read and use to determine whether or not the user in question is coming from our internal environment or from the public networks
Yes it’s possible with the HTTP::header insert command: Click here
HTTP::header insert header_1 value_3
log local0. “new header header_1 inserted with a value of [HTTP::header “header_1”]”
what is header_1 value_3 and why do i need log local0.
Header_1 represents a header name such as “user” or “host”
value_3 represents the actual value of “user” or “host”
log local0. Tells the iRULE to log the message between quotes to the ltm log file within BIGIP.
Exactly
I would strongly advise you to check how those commands work by looking at the wiki since you seem not to know much about iRules
it will help you a lot
OK, i guess i have to reinstate the question and describe my situation.
we have site: mycomany.com where IIS doing automaticaly redirect to the page
when users go to this site on port 80, we use BigIP iRule & redirect to port 443
Now, after we implemented trusted sign-on for internal users, based on source IP we want to redirect them to different authentication page.
we can’t use HTTP::redirect, since IIS doing some redirection automatacaly, in which case we will have NameBright - Coming Soon“IIS redirect” as one string in URL
We want to use HTTP header insert string, which vill be recognized by IIS and present different authentication based on the IP source.
I guess: Header_1 represents a header name such as “user” or “host” value_3 represents the actual value of “user” or “host”
not going to do much, since i don’t care about “user” and “host” - destination will be the same.
so, what are my options. where in this statement i can insert HTTP::header rule? and how does it going to look like?
how will it come across i.e.( STRING=1, STRING=true, or just the mere existence of STRING, which will signifies different source IP)
if {([TCP::local_port] eq “80”) and ([IP::client_addr] eq “10.x.x.x/16”)} {
HTTP::redirect “https://[HTTP::host][HTTP::uri]”
} elseif {[TCP::local_port] eq “80” } {
HTTP::redirect “http://[HTTP::host][HTTP::uri]”
pool Servers-Pool
What we gave you is an example of the syntax -_- not the solution. It was to help you understand the syntax.
You should have tried some search on this forum to find the answer by yourself…
When you do a redirect you can insert anything in the header so in your iRule you can insert HTTP header only in your else statement
If you had read the documentation about the HTTP::header insert you would have understand that header_1 would have been a new header created in the HTTP request which name would have been header 1 and its value would be the following data so in my example it would be value_3.
So to make it easy to understand:
  if {([TCP::local_port] eq "80") and ([IP::client_addr] eq "10.x.x.x/16")} {
    HTTP::redirect "https://[HTTP::host][HTTP::uri]"
  } elseif {[TCP::local_port] eq "80" } {
    HTTP::redirect "http://[HTTP::host][HTTP::uri]"
    HTTP::header insert STRING HERE_YOU_SPECIFY_THE_VALUE_YOU_WANT_STRING_TO_HAVE
    pool Servers-Pool
will it work this way???
if comming from address, inseart string, then look for port and redirect. (server will see string and based on the string presence will provide different page)
if {[IP::client_addr] eq “10.0.0.0/16”} {
HTTP::header insert STRING MLint
if {[TCP::local_port] eq “80”} {
pool eRoom-Servers-Pool
When you do this the logic will be
If client ip address equals 10.0.0.0/16 then insert or if the port = 80 then redirect, else go to pool.
It sounds like you need it to get past the first IF statement, before it checks the port, which is what your example wouldn’t do.
In that case perhaps you might want to do it the following:
if { [IP::addr 10.0.0.0/16 eq [IP::client_addr]] } {
    if { [TCP::local_port eq "80" } {
Hope that helps
/CB
tried to use this iRule, didn’t get any errors, but at the same time didn’t see any string incerted in Header. it does https redirect. Is there any other way to see that incert in header? i use ieHTTPheaders software to view. is anything else needs to be done on the BigIP side to enable this future.
thanks in advance for your help.
GET / HTTP/1.0
Accept: */*
Accept-Language: en-us
User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; MRA 5.0 (build 02094); .NET CLR 2.0.50727; IEMB3)
Host: BigIP-VIP-IP
Connection: Keep-Alive
X-NovINet: v1.2
HTTP/1.0 302 Found
Server: BIG-IP
Content-Length: 0
