illegal argument using HTTP::respond
Our application servers return a 200 OK message even if it should be a 404 or 500 error code, so we want to capture that using an iRule and return the right error code depending on the message returned by our app servers:
when HTTP_RESPONSE_DATA {
set page_not_found “The requested page was not found.”
set page_not_live “The requested page is not live.”
if { ([HTTP::payload] contains “$page_not_found”) } {
HTTP::respond 404
if { ([HTTP::payload] contains "$page_not_live) } {
HTTP::respond 500
It seems to be working as expected, however we see in the /var/ltm/log files the following error message:
- Illegal argument. Can’t execute in the current context. invoked from within “HTTP::payload”
I take the only mandatory attribute for the HTTP::respond is the error code.
HTTP::respond status_code [content] [noserver] [header_name header value]+
We’re using BIG-IP 9.4.8 Build 407.0 hotfix hf4
Any ideas?
Many thanks,
Victor
try adding the optional arguments: HTTP::respond 404 content “404”
I didn’t think the content parameter was necessary. In a quick test on 10.2.1, I don’t see a runtime error when using HTTP::respond 404 with no options.
Victor, maybe you could open a case with F5 Support to get a detailed review of your config and the errors.
Aaron
i don’t think it’s supposed to be, but I have seen issues with some configurations without it. Could be my sloppy code, though :wink:
Thanks for your comments. Much appreciated.
The issue was with the if statement.
I’ve fixed it taking out the [HTTP::payload] from the if statement and creating a new variable that I’ve used in the if statement, see below:
set payload [HTTP::payload]
if { $payload contains $page_not_found } {
Victor
