if HTTPS route to specified pool
I am trying to use a nested If statement to route to specific pools. In one situation, if the url is https:xxx then I want to route to different pool. Can this be done?
Here is an example of what I am trying to do:
if { [HTTP::host] eq “vs1.domain.com”} {
pool pool1
} elseif { [HTTP::host] eq “vs2.domain.com”} {
pool pool2
} elseif { [HTTP::host] eq “vs3.domain.com”} {
pool pool3
} elseif { [HTTPS::host] eq “vs.domain.com”} {
pool pool3ssl
pool defaultpool
Thanks in advance for any advice.
The one issue I see with your rule is that there is no “HTTPS::host” variable. You’ll have to check the “TCP::local_port” value to check whether this is on port 443 (https) or not.
ie.
  if { [HTTP::host] eq "vs1.domain.com"} {
    pool pool1
  } elseif { [HTTP::host] eq "vs2.domain.com"} {
    pool pool2
  } elseif { [HTTP::host] eq "vs3.domain.com"} {
    pool pool3
  } elseif { ([TCP::local_port] == 443) and ([HTTP::host] eq "vs.domain.com") } {
    pool pool3ssl
    pool defaultpool
-Joe
