idle timeout
Hi
is that possible to use specific idle time out with iRule.
for example i will set idle timeout 300 seconds in to the f4 profile and i want use 30 minutes idle timeout for specific port with iRule IP::idle_timeout
is that parameter read only ? (IP::idle_timeout)
thanks
zafer
Hi Zafer,
The idle timeout for the client and/or serverside connections can be retrieved or set with the IP::idle_timeout command. The wiki page has a few examples of doing both:
http://devcentral.f5.com/wiki/default.aspx/iRules/ip\_\_idle\_timeout
Aaron
Hi Aaron
You are right i checked link and it seem i can set different idle timeout value
the support guy told me its read only, i can not overwrite F4 profile timeout value
zafer
