Hi Dear,
I have two F5 series i4000, i need identify thah model is, i4600 or i4800. According to datasheet only difference of both is the compression, i4800 hardware compression and i4600 software compression.
With “show sys hardware”, show modelo type c115… With what command can identify precise model?
You should be able to find it in the configuration utility as well.
Log in to the Configuration utility.
Navigate to Device Management > Devices.
Click the local device with the (Self) designation.
The Platform ID field indicates the platform type. For example:
C106
The Platform Name field indicates the model name. For example:
BIG-IP 3900
Hope that helps! If it does please up-vote and select this answer, it would be greatly appreciated!
-Dylan
