Icontrol and PHP
I’m new to this and working with icontrol. I’ve executed many php pulling information from icontrol through CGI. However, i’m unable touse the below code,it comes up with blank page :
https://devcentral.f5.com/wiki/iControl.Getting-Started-with-iControl-and-PHP.ashx?NS=iControl
do i need to import or download WSDL into my web server? Please clarify or direct me to any help
thank you.
Two things:
  1. Can you enable display_errors in your PHP config to see if any errors are actually getting reported, and
  2. Do you have the SOAP module enabled?
SOAP Enabled..
[soap] soap.wsdl_cache_enabled=1 soap.wsdl_cache_dir=“/tmp” soap.wsdl_cache_ttl=86400
and error enabled.. but none reported.. kinda of strange
look in your php.ini and make sure the SOAP library extension isn’t commented out.
extension=php_soap.so
Hey, your suggestion helped. The SOAP.so directory was incorrect hence i added the following which fixed.
extension_dir =
Thank you so much.
