huge ucs archive
Hi guys !
I need your help!!
When saving ucs, huge files are saved for active devices.
But in case of standby device, small file is saved.
all of configuration is same I don’t know why this situation occur..
plz let me know it why this situation occur…
thank you!
Can you check if you have enough space under /var/local/ucs directory. if Space issue then try to generate UCS file to other location
Command : df -h ==> Space under /var directory
Try to login via cli and run these command to generate UCS file under '/shared/tmp/
tmsh save /sys ucs /shared/tmp/mytest.ucs
Hope issue will be solved
In most case, if pcap file wasn`t save in /var/tmp/ then that file also save in ucs file.
So, find out .pcap file in all directory and clear.
This cased by policy versions/history, you can delete it manually using WinSCP navigate to /var/ts/dms/policy/policy_versions/ then delete all folders. or CLI by login into BASH
cd /var/ts/dms/policy/policy_versions/
 ls -hl
rm -rf *
