is it possible to redirect a https url ? for example, when https://page1.com arrives can an irule redirect to https://page2.com
Create an iRule and attach it to your virtual server. The iRule should be along these lines:
when HTTP_REQUEST { if { [HTTP::host] equals “page1.com”} { HTTP::redirect "; } }
Check for more examples here: https://devcentral.f5.com/wiki/iRules.HTTP__host.ashx
Do not do use iRules to do that… use policies ! Check this link: DevCentral - An F5 Technical Community
The steps might be a little bit different from the version that you are using.
Please try below irule
when HTTP_REQUEST { if { [HTTP::host] equals "; } { HTTP::redirect "; } }
Make sure http profile is enabled for virtual server if not you will not be able to assign irule
Redirection can be achieve by either F5 policy(V11.3 onward) or iRule.
- Policy is the best option to achieve this kind of redirection, same already discussed by @WithF5. In-fact F5 policy is good to explore in new era.
Option 2. Same can be achieve via iRule. iRule is already shared by devcentral Colleague. Did some modification in above iRule. Hope it will work for you.
if { ([string tolower [HTTP::host]] equals "page1.com") && ([TCP::local_port] == 443)} {
HTTP::redirect "http://page2.com"
Bearing in mind that all the responses so far are relying on the fact that you’ve configured your https virtual server with the appropriate profiles (e.g. client ssl, http)
Thank you f5_rock, This works ! Great idea checking port, when 443 then apply redirect.
