Hello F5 Champs,
I am new to F5 and have just started working on it since the past few months.. still trying to learn the nitty gritty of F5s and i rules.. Need some guidance with the below task (creating an irule)
The users are currently accessing http://abc.xyz.com:8080.. The application team is planning to change the application to https with the new URL as https://abc.xyz.com:8443
The requirement here is that if the user hits http://abc.xyz.com:8080 , it should redirect to the new one i.e. https://abc.xyz.com:8443
Any help/guidance would be much appreciated
Hello.
To do so, you should create a VS listening in port 8080 and apply an iRule like this
HTTP::respond 301 Location "https://[HTTP::host]:8443[HTTP::uri]"
After that, you should create another VS listening in port 8443 with an client_SSL profile to process all the requests.
KR,
Dario.
Hello,
I think you can do the same also with a redirect profile applied to your virtual server running on port 8080. As Dario said you have to configure also a new virtual server listening on port 8443.
Redirect profile or you mean redirect in http profile?
How exactly is this used, cant find any place to add the new URL!
I think Luca means to use a policy for redirection (instead of an iRule)
REF - https://www.youtube.com/watch?v=xk0SeeDEg1Y
REF - Lab 6: BIG-IP Policies and iRules
KR,
Dario.
Yes sorry, I was meaning a redirect policy as Dario said.
Luca
