https to 8081 redirection
I have a requirement of doing an client ssl offload on the BIG-IP and then redirect it to port 8081.
For eg: a user will enter in the browser https://a.b.c.d then big-ip will offload it and should redirect it to [u]**http://a.b.c.d:8081/sm/index.do**[/u]
I will appreciate help on this case, as Iam very new to writing an irule.
Thanks in advance,
Mubasher
I assume the port member is listening on port 8081? If that’s the case there is no need to specify the port in the redirect;
 if { [HTTP::uri] equals "/" } {
 HTTP::redirect "https://[HTTP::host]/sm/index.do"
i think you mean uri rewriting rather than redirection.
e.g.
[root@ve10:Active] config  b virtual bar list
virtual bar {
   snat automap
   pool foo
   destination 172.28.19.252:443
   ip protocol 6
   rules myrule
   profiles {
      clientssl {
         clientside
      http {}
      tcp {}
[root@ve10:Active] config  b pool foo list
pool foo {
   members 200.200.200.101:8081 {}
[root@ve10:Active] config  b rule myrule list
rule myrule {
   if { [HTTP::uri] eq "/" } {
      HTTP::uri "/sm/index.do"
 test
[root@ve10:Active] config  ssldump -Aed -nni 0.0 port 443 or port 8081 -k /config/ssl/ssl.key/default.key
New TCP connection 1: 172.28.20.17(36729) <-> 172.28.19.252(443)
1 1  1367328173.8100 (0.0179)  C>S SSLv2 compatible client hello
1 2  1367328173.8101 (0.0000)  S>CV3.1(81)  Handshake
1 3  1367328173.8101 (0.0000)  S>CV3.1(953)  Handshake
1 4  1367328173.8101 (0.0000)  S>CV3.1(4)  Handshake
1 5  1367328173.8123 (0.0021)  C>SV3.1(262)  Handshake
1 6  1367328173.8123 (0.0000)  C>SV3.1(1)  ChangeCipherSpec
1 7  1367328173.8123 (0.0000)  C>SV3.1(36)  Handshake
1 8  1367328173.8297 (0.0174)  S>CV3.1(1)  ChangeCipherSpec
1 9  1367328173.8297 (0.0000)  S>CV3.1(36)  Handshake
1 10 1367328173.8321 (0.0023)  C>SV3.1(169)  application_data
    GET / HTTP/1.1
    User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8b zlib/1.2.3 libidn/0.6.5
    Accept: */*
    Host: a.b.c.d
New TCP connection 2: 200.200.200.10(36729) <-> 200.200.200.101(8081)
1367328173.8332 (0.0010)  C>S
GET /sm/index.do HTTP/1.1
Accept: */*
Host: a.b.c.d
