HTTP_RESPONSE not firing
Hi there,
I’m using the ProxyPass v10 iRule to perform some path rewriting on some of our VIP’s…
However we seem to be getting some sporadic issues whereby the HTTP_RESPONSE event isn’t being triggered when the request is being processed.
This results in the site breaking as all the resource paths etc aren’t being re-written by the ProxyPass irule…
An example debug log is:
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/HandleErrors : Processing HTTP_REQUEST at Priority 20…
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/HandleErrors : $maintenance_mode = 0, $ssl_error = 0, $failure_result = ‘’
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/CacheControl : CacheControl HTTP Request at Priority 50:
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/CacheControl : HTTP Request for Host: 192.168.151.15 URI: /home.faces
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/CacheControl : GET Method, enabling Cache
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/HandleErrors : Processing HTTP_REQUEST at Priority 750…
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/HandleErrors : $pool_error = 0
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/HandleErrors : Passed error checking… Continuing…
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Processing ProxyPass HTTP_REQUEST
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Not In Maintenance mode. Continuing…
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Virtual Name = /Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, $vname = portal.comportal3.test.card.co.uk, $cname = portal, $clname = ProxyPass_portal
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: HTTP connection
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Data Group ProxyPass_portal found.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: $ppass = ‘/ /CommercialPortal’
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: ProxyPass_ value = / /CommercialPortal
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Clientside: Path starts / Host Clientside=192.168.151.15, Path Clientside=/.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Serverside: Host Serverside=192.168.151.15, Path Serverside=/CommercialPortal.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : Appending / to Path Serverside.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Found Rule, Original Path=/home.faces, Client Host=192.168.151.15, Client Path=/, Server Host=192.168.151.15, Server Path=/CommercialPortal/
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Using default pool /Common/comportal3.test.app/comportal3.test_pool
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: $bypass value = 0
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Continuing with rest of HTTP_REQUEST block.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/CacheControl : Cache_Request for Host: 192.168.151.15 URI: /home.faces
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Processing HTTP_REQUEST_SEND block.
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: New Host=192.168.151.15, New Path=/CommercialPortal/home.faces
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/ProxyPass : VS=/Common/comportal3.test.app/portal.comportal3.test.card.co.uk_http, Host=192.168.151.15, URI=/home.faces: Inserting header: X-Forwarded-For: 192.168.100.208
Feb 7 17:03:53 tmm info tmm[9144]: Rule /Common/CacheControl : HTTP Request for Host: 192.168.151.15 URI: /CommercialPortal/javax.faces.resource/style.css.faces;jsessionid=8c584e5692cb13a77d7628839ebb?ln=commercial/css
AS you can see it’s quite happily processing upto the HTTP_REQUEST_SEND block, but just receives no HTTP_RESPONSE.
However the browser appears to receive a response and moves onto requesting some of the non-rewritten resources. E.g. on the last line where it still contains ‘CommercialPortal’…
Relevant config:
gavinw@actint-star-f501(Active)(/Common)(tmos) list /ltm virtual comportal3.test.app/portal.comportal3.test.card.co.uk_http
ltm virtual comportal3.test.app/portal.comportal3.test.card.co.uk_http {
app-service /Common/comportal3.test.app/comportal3.test
destination 192.168.151.15:http
ip-protocol tcp
mask 255.255.255.255
pool comportal3.test.app/comportal3.test_pool
profiles {
Caching_CommPortal { }
HTTP_Rewrite { }
oneconnect { }
stream { }
tcp-wan-optimized { }
wan-optimized-compression { }
rules {
ProxyPass
SplunkHTTP
CacheControl
CatchErrors
HeaderStripping
MaintenancePage
UnavailablePage
HandleErrors
snat automap
vlans-disabled
gavinw@actint-star-f501(Active)(/Common)(tmos) list /ltm profile web-acceleration Caching_CommPortal
ltm profile web-acceleration Caching_CommPortal {
app-service none
cache-uri-exclude { /home.faces }
cache-uri-include { .* }
cache-uri-include-override none
cache-uri-pinned { /javax.faces.resource/* }
defaults-from optimized-caching
gavinw@actint-star-f501(Active)(/Common)(tmos) list /ltm profile http HTTP_Rewrite
ltm profile http HTTP_Rewrite {
app-service none
defaults-from http
redirect-rewrite matching
gavinw@actint-star-f501(Active)(/Common)(tmos) list /ltm profile one-connect oneconnect
ltm profile one-connect oneconnect {
idle-timeout-override disabled
max-age 86400
max-reuse 1000
max-size 10000
source-mask any
gavinw@actint-star-f501(Active)(/Common)(tmos) list /ltm profile stream stream
ltm profile stream stream {
source none
target none
Any ideas what might cause this???
Cheers
Gavin
I’ve done some further testing and I’m still getting the occasional issue…
Haven’t yet been able to identify a trigger…
Any ideas???
Cheers
Gavin
The only thing that jumps out at me is that you’re using caching. If a cached document is served, HTTP_RESPONSE won’t fire, but CACHE_RESPONSE will. Try adding a log statement to CACHE_RESPONSE and see if that lines up with the times that HTTP_RESPONSE isn’t firing.
Spark
Cheers for the response…
I did think of that aswell… I’ve had a look and I have in-fact got some logging for those events on the CacheControl rule…
An example log output from those is:
Feb 10 13:54:46 tmm info tmm[9144]: Rule /Common/CacheControl : Cache_Request for Host: 192.168.151.15 URI: /javax.faces.resource/images/footer_bg.png.faces?ln=commercial
Feb 10 13:54:46 tmm info tmm[9144]: Rule /Common/CacheControl : Cache_Response for Host: 192.168.151.15 URI: /javax.faces.resource/images/footer_bg.png.faces?ln=commercial
So it doesn’t look like the CACHE_RESPONSE is being fired either :frowning:
I’m starting to wonder if it’s a OneConnect issue…
Any thoughts???
Cheers
Gavin
Hi Gavin,
With eight iRules it’s hard to guess why you wouldn’t see HTTP_RESPONSE being triggered in the ProxyPass iRule. Your best bet might be to open a case with F5 Support. They’ll be able to review your full config to troubleshoot this. Make sure to let them know you don’t want them to write your iRules for you--just troubleshoot why your existing config isn’t behaving as expected. If you get stuck with support, reply here with your case number and I’ll try to take a look.
Aaron
Aaron
Will do…
Gavin
As a further update, I’ve logged this issue with F5 support… yet to receive a response…
Also, I’ve done some further testing, and it appears to be whenever this fault condition occurs, all iRule processing is bypassed, on both the inbound and outbound.
Are there any known issues that might trigger this? Is OneConnect a possible suspect?
Cheers
Gavin
Ah hah… Found it…
This rule was causing the errors…
when RULE_INIT {
set static::ErrorDebug 1
when HTTP_REQUEST priority 50 {
if {$static::ErrorDebug == 1} { log local0. "CatchErrors HTTP Request at Priority 50:" }
 Record request details encase needed later.
set HTTP_HOST [HTTP::host]
set HTTP_URI [HTTP::uri]
set HTTP_METHOD [HTTP::method]
set VSPool [LB::server pool]
if {$static::ErrorDebug == 1} { log local0. "\$HTTP_HOST = $HTTP_HOST, \$HTTP_URI = $HTTP_URI, \$HTTP_METHOD = $HTTP_METHOD, \$VSPool = $VSPool" }
if { [active_members $VSPool] < 1 } {
LB::detach
log local0. "Client [IP::client_addr] requested [HTTP::host][HTTP::uri] no active nodes available."
 No pool members available. Setting error flag.
set pool_error 1
when HTTP_RESPONSE priority 100 {
 Catch Bad Application Errors and set relevant error flag
if { $HTTP_METHOD == "GET" } {
if { [HTTP::status] == 404 or [HTTP::status] == 500 or [HTTP::status] == 502 or [HTTP::status] == 503 } {
log local0.info "Error encountered. Returning unavailable page. Request details: HTTP_HOST=$HTTP_HOST, HTTP_URI=$HTTP_URI, HTTP_METHOD=$HTTP_METHOD, VSPool=$VSPool, HTTP_Status=[HTTP::status]"
set response_error 1
return
Removed it from the VIP and it’s now 100% success rate…
Now to try and work out why this rule would cause the issues i was seeing…
Gav
That iRule on its own shouldn’t prevent other iRules from firing. Do your other iRules read the $response_error or $pool_error variables?
Aaron
Aaron
Yes, I’ve got another rule that’s handling all the error variables… Code is:
when RULE_INIT {
set static::RespondDebug 1
 Static iFile content
set static::unavailable_page [ifile get unavailable_page_html]
set static::offline_page [ifile get offline_page_html]
set static::secure_failure_page [ifile get secure_connection_failure_html]
set static::act_logo [ifile get act_logo_png]
when CLIENT_ACCEPTED priority 1 {
if {$static::RespondDebug > 0} { log local0. "Processing CLIENT_ACCEPTED at priority 1" }
 Set-up base variables.
set pool_error 0
set maintenance_mode 0
set ssl_error 0
set failure_result ""
set response_error 0
if {$static::RespondDebug > 0} { log local0. "Variables set:- \$pool_error = $pool_error, \$maintenance_mode = $maintenance_mode, \$ssl_error = $ssl_error, \$failure_result = '$failure_result', \$response_error = $response_error" }
when HTTP_REQUEST priority 20 {
 Variable set-up.
set vname "[findstr [string range [virtual name] [string last / [virtual name]] end] "/" 1 "_"]"
set host "[HTTP::host]"
set uri "[HTTP::uri]"
set errors_prefix "VS=$vname, Host=$host, URI=$uri"
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: Processing HTTP_REQUEST at Priority 20..." }
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: \$maintenance_mode = $maintenance_mode, \$ssl_error = $ssl_error, \$failure_result = '$failure_result'" }
 Catch ACT Logo and return.
if { [HTTP::uri] ends_with "logo-act.png" } {
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: Returning ACT Logo..." }
HTTP::respond 200 content $static::act_logo "Content-Type" "image/png" "Connection" "Close" "Cache-Control" "no-cache"
TCP::close
event disable
return
 Catch Scheme Logo(s) and return.
if { [HTTP::uri] ends_with "_logo.jpg" } {
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: Returning Scheme Specific Logo's..." }
 Set-up iFile name.
set ifile_name "scheme_error_logo_"
set scheme_ref [class lookup $vname Scheme_Error_VIP_Names]
append ifile_name $scheme_ref
append ifile_name "_"
 Get Logo name from URI
set logo_name [string trim [getfield [HTTP::uri] "/" 3] "_logo.jpg"]
append ifile_name $logo_name
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: Logo name is: '$ifile_name'" }
 Get iFile content
catch {ifile get $ifile_name} response_content
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: Response content is: '$response_content'" }
if { $response_content == "" } {
log local0.info "$errors_prefix: Logo not found..."
HTTP::respond 200 "Connection" "Close" "Cache-Control" "no-cache"
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: Returning logo..." }
HTTP::respond 200 content $response_content "Content-Type" "image/jpg" "Connection" "Close" "Cache-Control" "no-cache"
TCP::close
event disable
return
 Handle maintenance mode.
if {$maintenance_mode} {
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: Returning Maintenance page html..." }
switch -glob [HTTP::method] {
POST {
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: POST Method - Returning Code 503" }
HTTP::respond 503
event disable
return
GET {
 Scheme specific error page handling.
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: GET Method - Checking for Custom error page" }
if { [class match $vname eq Scheme_Error_VIP_Names] } {
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: $vname found in Scheme_Error_VIP_Names" }
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: Scheme reference is: '$scheme_ref'" }
set response_html [ifile get scheme_error_html_$scheme_ref]
HTTP::respond 200 content $response_html "Content-Type" "text/html" "Cache-Control" "no-cache"
if {$static::RespondDebug > 0} { log local0. "$errors_prefix: $vname not found in Scheme_Error_VIP_Names" }
HTTP::respond 200 content $static::offline_page "Content-Type" "text/html" "Cache-Control" "no-cache"
event disable
return
TCP::close
 Handle SSL error
if {$ssl_error} {
if {$static::RespondDebug > 0} { log local0. "Returning SSL Error page html..." }
HTTP::respond 403 content [subst $static::secure_failure_page] "Content-Type" "text/html" "Connection" "Close"
TCP::close
event disable
return
when HTTP_REQUEST priority 750 {
if {$static::RespondDebug > 0} { log local0. "Processing HTTP_REQUEST at Priority 750..." }
if {$static::RespondDebug > 0} { log local0. "\$pool_error = $pool_error" }
 Handle error page.
if {$pool_error} {
POST {
if {$static::RespondDebug > 0} { log local0. "POST Method - Returning Code 503" }
HTTP::respond 503
event disable
return
GET {
HTTP::respond 200 content $static::unavailable_page "Content-Type" "text/html" "Cache-Control" "no-cache"
event disable
return
TCP::close
if {$static::RespondDebug > 0} { log local0. "Passed error checking... Continuing..." }
return
when HTTP_RESPONSE priority 250 {
if {$static::RespondDebug > 0} { log local0. "Processing HTTP_RESPONSE... at Priority 250" }
if {$static::RespondDebug > 0} { log local0. "\$response_error = $response_error" }
if {$response_error} {
switch -glob [string toupper $HTTP_METHOD] {
"POST" {
HTTP::respond 503
event disable
return
"GET" {
event disable
return
But all the logs show that $pool_error and $response_error are at 0.
Cheers
Gav
All
I’ve done some further testing this morning, and I think I may have found a possible cause…
Within the above CatchErrors rule, I’m creating 3 variables, of the format ‘HTTP_X’. When I change these variables to be ‘ERROR_X’, the rule works as I’d expect it to, and I don’t get any issues.
So I’m wondering if the ‘HTTP_’ prefix has some bigger meaning when the iRules are being parsed…
After identifying the above, I’d re-written the rule to use a set of shared variables which I create at the beginning of the connection. For reference, the CatchErros rule now looks like:
when RULE_INIT {
set static::CatchErrorsDebug 0
if {$static::CatchErrorsDebug == 1} { log local0. "CatchErrors HTTP Request at Priority 50:" }
LB::detach
log local0. "Client [IP::client_addr] requested $host$uri no active nodes available."
set pool_error 1
return
if {$static::CatchErrorsDebug == 1} { log local0. "Active Pool members [active_members $VSPool] > 0. Continuing..." }
if {$static::CatchErrorsDebug == 1} { log local0. "CatchErrors HTTP Response at Priority 100:" }
if { $method == "GET" } {
set ERROR_STATUS [HTTP::status]
 log local0.info "Error encountered. Returning unavailable page. Request details: Host=$host, URI=$uri, METHOD=$method, ClientIP=$clientip VSPool=$VSPool, HTTP_Status=$ERROR_STATUS"
return
So for now, it looks like problem solved.
I did get a courtesy call from Masimo @ F5 in London this afternoon apologies for not responding to my websupport case, and advising that someone should be looking over the weekend. So thanks for that call Masimo, and hopefully the above will prove useful for the investigating engineer.
Anybody else come across this issue though???
Cheers
Gavin
HTTP_* shouldn’t have any special meaning for TMM. Do you have references to these variable names in your other iRules?
Aaron
Aaron
These variables were being set in this rule, and used in the 2nd rule posted above to decide if an error has been encountered which needs to be handled…
Now that I’ve re-written the rules, it’s been rock-solid… So must be *something* strange going on…
Cheers
Gav
