Guys i need a help. I just want the F5 VIP after assigning an HTTP compression profile, to only compress PNG and JPEG images and nothing else since the backend servers is compressing everything else.
Please see About HTTP compression profiles.
helps you to compress your jpegs & pngs without affecting the quality of the image.
jpeg compress offers a simple and easy-to-use interface. On the landing page of this website directly offers the feature of compressing jpg or jpeg files and images.It compresses the images with higher accuracy by not losing the original quality of the uploaded images.
Hey hi, you can customize the HTTP compression profile. In the compression profile setting specify the MIME types for PNG and JPEG images to check that only these types are compressed and other content types will not be compressed since the backend servers are already handling them. On the other hand you can compress you images by using any online application such as https://jpegcompressor.com/ it compress images without losing their quality.
