Compression does not work
hello ,
I create compression profiles with these content . and add this profile my standart + http profile .. But both does not make any content compression. What  I am missing ?
Hi Ozzy,
Can you do a browser test to the VIP and use developer tools in the browser and look for the “Content-Encoding” header in the HTTP response?  You should see that header along with a value of gzip/deflate/ etc.  You can also use a curl statement to test/verify as well:
curl -I -H “Accept-Encoding: gzip, deflate, br” https://yourwebsite.com
Additionally, you can try to compare file sizes of the content your are trying to access by using adjusting the “Accept-Encoding” headers:  some examples below:
With compression: curl -H “Accept-Encoding: gzip” https://yourwebsite.com > compressed.html
Without compression: curl -H “Accept-Encoding: empty” https://yourwebsite.com > uncompressed.html
Compare file sizes using
The backend web server also need to support this, if its  Nginx - check for gzip on   if its Apache - mod_deflate,
I can not see any encoding header with
curl -I -H “Accept-Encoding: gzip, deflate,br” https://wiki-test.company.com
HTTP/1.1 404 Not Found
Date: Fri, 04 Apr 2025 14:45:39 GMT
Server: BigIP
Content-Length: 3186
Connection: close
Content-Type: text/html; charset=utf-8
X-Frame-Options: DENY
04/04/2025  16:48                 0 compressed.html
04/04/2025  16:48                 0 uncompressed.html
               2 File(s)              0 bytes
               0 Dir(s)  194,474,168,320 bytes free
should I undertand , backend server does not support compression ?
