Hello.
1. Your solution
I tried your solution, here is the nginx configuration.
<GITLAB-HOST> is the host of my gitlab gitlab.mycompany.com.
server {
listen 443 ssl;
server_name <GITLAB-HOST>;
ssl_certificate /etc/nginx/certs/mycert.crt;
ssl_certificate_key /etc/nginx/certs/mykey.key;
ssl_session_cache shared:SSL:1m;
ssl_prefer_server_ciphers on;
access_log /var/log/nginx/mysite.access.log;
error_log /var/log/nginx/mysite.error.log debug;
location / {
proxy_set_header Host $http_host;
proxy_connect_timeout 60;
proxy_read_timeout 60;
proxy_send_timeout 60;
proxy_intercept_errors off;
proxy_http_version 1.1;
proxy_set_header X-Real-IP $remote_addr;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
proxy_set_header X-Forwarded-Proto $scheme;
proxy_pass https://<PROXY-IP>:<PROXY-PORT>;
I got a timeout error message when I tried git clone command from a client.
git clone https://<LOGIN>@<GITLAB-HOST>/myrepo.git
Cloning into 'myrepo'...
fatal: unable to access 'https://<LOGIN>@<GITLAB-HOST>/myrepo.git/': Failed connect to <GITLAB-HOST>:443; Connection timed out
I think it is normal to get a timeout, because the client tries to reach directly <GITLAB-HOST> without passing through nginx, and direct connections are impossible. I saw nothing in the nginx logs.
2. Second retry
I tried the following modification from your solution.
<DNS-ALIAS-NGINX-GITLAB> is an alias DNS that I created especially for clients to send git requests to nginx host.
server {
listen 443 ssl;
server_name <DNS-ALIAS-NGINX-GITLAB>;
location / {
When I retried my git clone command, I got this error :
git clone https://<LOGIN>@<DNS-ALIAS-NGINX-GITLAB>/myrepo.git
fatal: unable to access 'https://<LOGIN>@<DNS-ALIAS-NGINX-GITLAB>/myrepo.git/': The requested URL returned error: 502
I saw this error message in nginx logs :
2022/11/04 16:16:23 [error] 18473#18473: *1 SSL_do_handshake() failed (SSL: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol) while SSL handshaking to upstream, client: <CLIENT-IP>, server: <DNS-ALIAS-NGINX-GITLAB>, request: "GET /myrepo.git/info/refs?service=git-upload-pack HTTP/1.1", upstream: "https://<PROXY-IP>:<PROXY-PORT>/myrepo.git/info/refs?service=git-upload-pack", host: "<DNS-ALIAS-NGINX-GITLAB>"
I don’t really understand the error here, but something bothers me in this solution. I never mention in nginx conf the final host, so I don’t think it can work.
3. Another modification
I tried to set the Host header to the final gitlab-host. As the forward proxy and the gitlab host listens to different port number, I had to specify the final gitlab-host port in the Host header.
server {
listen 443 ssl;
ssl_certificate /etc/nginx/certs/mycrt.crt;
location / {
proxy_set_header Host <GITLAB-HOST>:443;
But I got the same error than in the second try (in my git command and in nginx logs)
2022/11/04 16:34:39 [error] 20677#20677: *5 SSL_do_handshake() failed (SSL: error:140770FC:SSL routines:SSL23_GET_SERVER_HELLO:unknown protocol) while SSL handshaking to upstream, client: <CLIENT-IP>, server: <DNS-ALIAS-NGINX-GITLAB>, request: "GET /myrepo.git/info/refs?service=git-upload-pack HTTP/1.1", upstream: "https://<PROXY-IP>:<PROXY-PORT>/myrepo.git/info/refs?service=git-upload-pack", host: "<DNS-ALIAS-NGINX-GITLAB>"
May you help me to succeed, please ?
Best regards.
