Hi guy
I’ve a request from customer that they want to using F5 SDN with cisco ACI.
And I can’t find guide about this technology nor manual about What is SDN? Is it something new and not practical or complex implement?
May I ask you where can I find document about F5 SDN (or just SDN Technology concept) or how to start with F5 SDN?
Thank you very much
PSilva
2
Hi~ These links, including our Cisco ACI Reference Archtecture, should get you started:
[https://f5.com/resources/white-papers/extending-sdn-architectures-with-f5s-l47-application-and-gateway-services]
Hope that helps and let us know if you need anything else! ps
The F5 and Cisco APIC integration based on the device package and iWorkflow is End Of Life.
The latest integration is based on the Cisco AppCenter named ‘F5 ACI ServiceCenter’.
Click here to view the Cisco ACI and F5 BIG-IP design guide which discusses the following topics:
- SNAT or no SNAT
- BIG-IP redundancy
- Multi-tenancy
- Tighter integration using F5 ACI ServiceCenter
Visit F5 and Cisco ACI Essentials - Design guide for a Single Pod APIC cluster - F5 Technical Articles - DevCentral - An F5 Technical Community to learn how to access a lab for hands on experience using the F5 ACI ServiceCenter
Cisco ACI and F5 BIG-IP Integration | F5 for updated information on the integration.
