I’m trying to solve what seems like a fairly simple problem for which there should already be an answer, yet I cannot find an answer.
Use case: In Windows 7 At work, no VPN is required, Startup scripts launches apps. Out of office, VPN is required BEFORE apps launch.
What is the recommended solution for this common use case?
Currently I have a .BAT file that runs to detect my network IP. If it start with a specific octet, I know I’m at work. I don’t need VPN, so I launch my apps
If it’s any other octet, I know I’m not at work. I can launch f5fpclientW.exe.
Ideally I’d like f5fpclientW.exe to run a script after successful connection. But I don’t see this in the GUI.
The alternative is for the .BAT file to watch the net interfaces and have it wait for the VPN connection to come up. This is seems like a kludge to me as this appears to be a common use case for which a solution should already exist.
Thanks,
Paul
