How to issue shell command from tmsh?
I am trying to automate f5 using ansible and need way to fetch and put back the masterkey. The master key fetching is done by command “f5mku -K” which gets executed on native shell. How can i execute this command from tmsh? Ansible command modules by default use tmsh hence the requirement.
Alternatively, way to fetch and apply the master key from the tmsh will also help.
We can use the following option:
run /util bash -c “f5mku -K”
