How can I specify a very specific Cipher string?
The object is to only allow the ciphers below and offer them in this specific order.
TLS13-AES256-GCM-SHA384/TLS1.3
TLS13-CHACHA20-POLY1305-SHA256/TLS1.3
TLS13-AES128-GCM-SHA256/TLS1.3
ECDHE-ECDSA-AES256-GCM-SHA384/TLS1.2
ECDHE-ECDSA-CHACHA20-POLY1305-SHA256/TLS1.2
ECDHE-ECDSA-AES128-GCM-SHA256/TLS1.2
ECDHE-RSA-AES256-GCM-SHA384/TLS1.2
ECDHE-RSA-CHACHA20-POLY1305-SHA256/TLS1.2
ECDHE-RSA-AES128-GCM-SHA256/TLS1.2
ECDHE-RSA-AES256-CBC-SHA/TLS1.2
ECDHE-RSA-AES128-CBC-SHA/TLS1.2
Is this possible at all?
'TLS13-AES256-GCM-SHA384:TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-CHACHA20-POLY1305-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-CBC-SHA:ECDHE-RSA-AES128-CBC-SHA:!TLSv1:!TLSv1_1'
# tmm --clientciphers 'TLS13-AES256-GCM-SHA384:TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-CHACHA20-POLY1305-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-CBC-SHA:ECDHE-RSA-AES128-CBC-SHA:!TLSv1:!TLSv1_1'
ID SUITE BITS PROT CIPHER MAC KEYX
0: 4866 TLS13-AES256-GCM-SHA384 256 TLS1.3 AES-GCM NULL *
1: 4867 TLS13-CHACHA20-POLY1305-SHA256 256 TLS1.3 CHACHA20-POLY1305 NULL *
2: 4865 TLS13-AES128-GCM-SHA256 128 TLS1.3 AES-GCM NULL *
3: 49196 ECDHE-ECDSA-AES256-GCM-SHA384 256 TLS1.2 AES-GCM SHA384 ECDHE_ECDSA
4: 52393 ECDHE-ECDSA-CHACHA20-POLY1305-SHA256 256 TLS1.2 CHACHA20-POLY1305 NULL ECDHE_ECDSA
5: 49195 ECDHE-ECDSA-AES128-GCM-SHA256 128 TLS1.2 AES-GCM SHA256 ECDHE_ECDSA
6: 49200 ECDHE-RSA-AES256-GCM-SHA384 256 TLS1.2 AES-GCM SHA384 ECDHE_RSA
7: 52392 ECDHE-RSA-CHACHA20-POLY1305-SHA256 256 TLS1.2 CHACHA20-POLY1305 NULL ECDHE_RSA
8: 49199 ECDHE-RSA-AES128-GCM-SHA256 128 TLS1.2 AES-GCM SHA256 ECDHE_RSA
9: 49172 ECDHE-RSA-AES256-CBC-SHA 256 TLS1.2 AES SHA ECDHE_RSA
10: 49171 ECDHE-RSA-AES128-CBC-SHA 128 TLS1.2 AES SHA ECDHE_RSA
I removed the CBC Ciphers to be compliant with SSL Labs weak ciphers list :
TLS13-AES256-GCM-SHA384:TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-CHACHA20-POLY1305-SHA256:ECDHE-RSA-AES128-GCM-SHA256:!TLSv1:!TLSv1_1
In general, I would make the same recommendation, but the original request was for a specific set of ciphers. There are still some older clients that require CBC ciphers, and cannot be upgraded easily (embedded devices like Smart Meters, for example).
