How to assign a Fallback Persistence?
Hello All,
I got a requirement where the fallback persistence is needed to apply. Since I never worked on it, not sure how to assign it to the virtual server. Can someone please provide the steps to create a fallback persistence or how to apply it? I checked using “list ltm persistence” command but don’t see it there.
f5 version - 11.5.4
Thank you,
R
If you have no experience then it might be easier for you to just assign a fall-back persistence from the GUI.
FWIW in tmsh the fallback is fallback-persistence
You’d set the persistence with something like
modify vs_name fallback-persistence fb-persist-profile
and create (Before you add it obviously) the persistence profile via something like
create /ltm persistence source-addr profile-name
The type (Where I have source-addr) can be one of the supported types. e.g. cookie, src/dst-addr etc.
