How add data in payload requests
I have to 'live" update a post field in a payload request before forwarding the request to ASM.
I found how to get the payload data with a collect when HTTP_REQUEST and then a payload split when HTTP_REQUEST_DATA to retrive the specific parameter.
- How can I now inject a updated value for it in payload with if needed, update content-lenth ?
Thanks in advance,
Rodolphe. (FR)
Hi Rodolphe,
You can use HTTP::payload to retrieve and replace the entire payload or parts thereof:
http://devcentral.f5.com/wiki/default.aspx/iRules/http\_\_payload
Aaron
Can I do the same thing with TCP::payload. I need to add a SENDER field to an outbound email. I am trying TCP::payload replace… but that does not seem to be working?
Thanks,
Tom
