Host re-direct except for directory?
I’ve been trying to use this re-direct to re-direct a main domain e.g. www.oil.com to www.test.com/abc but I dont want www.oil.com/ger to re-direct
Here is what I’ve been trying to use but when I go to www.oil.com/ger its still re-directing
    Check if domain is "www.domain.com"
   if {[string tolower [HTTP::host]] eq www.oil.com}{
       Check if URI isn't /specialdirectory
       switch [HTTP::uri] {
         "/ger" {
             Exit this event from this iRule
            return
    Redirect everything else to the following
   HTTP::redirect "http://www.test.com/abc" }
Try this:
    if {[string tolower [HTTP::host]] eq "www.oil.com"}{
        switch -glob [string tolower [HTTP::uri]] {
           "/ger" -
           "/ger/" -
           "/ger/*" {
                return
           default {
Update: Whoops. Shouldn’t try typing fast before I’ve had my coffee. Missed a closed bracket and quotes.
Thanks Joel am getting the following error
line 3: [parse error: PARSE syntax 107 {syntax error in expression “[string tolower [HTTP::host]] eq www.oil.com”: variable references require preceding $}] [{[string tolower [HTTP::host]] eq www.oil.com}]
Put www.oil.com in quotes. And you don’t need the string tolower on HTTP::host.
I’ve updated the rule above.
@Jason: Most browsers will convert the Host: header to lowercase if the user specifies it in mixed or uppercase in the Address bar -- but not all do. And if you look at RFC-2396 (URI specifications), it’s totally silent on case conversion in the authority section of a URI (section 3.2) but explicitly states it in the scheme section (section 3.2)… and then goes on in section 6 (URI normalization) to describe an authority “host” as merely “equivalent” when mixed case but does not _require_ it to be normalized.
Which is why I’ve found plenty of tools that will happily set a Host header with mixed case! Some web-crawlers, for example. Dang “standards”…
I think you’ve still got an extra ] here:
if {[string tolower [HTTP::host]] eq "www.oil.com"]}{
Many thanks Joel I’ve just tested the irule and it works perfectly thanks again for your help.
Pav
Absolutely -- good to hear it’s working for you; glad to help.
