I have an iRule that extracts some data from a TCP connection and uses it for the persistence value. The first 4 bytes are treated as a magic value and the persistence is only applied if the magic value is correct (defined by the protocol)
The protocol documentation defines all constants like this in hex, and I’d prefer to have the values in the code also be in hex. From the documentation it looks like TCL handles hex values properly, but I’m having trouble getting it to work.
Here’s my iRule:
when CLIENT_ACCEPTED {
TCP::collect 8
when CLIENT_DATA {
set dataVal [TCP::payload]
set numScanned [binary scan $dataVal II magic id]
if { $numScanned < 2 } {
binary scan $dataVal H16 hexRep
log local0. "TCP connection didn't receive enough data: $hexRep"
return
switch -- $magic {
0x003A1F87 {
magic == 0x003a1f87 == 3809159
set persistVal $id
log local0. "Persisting connection: $persistVal"
persist uie $persistVal
default {
log local0. "Got socket connection with invalid magic value: $magic"
Using this iRule the default case is always hit. However, if I replace the hex value with the decimal value:
switch -- $magic {
3809159{
it works fine.
How come the hex value isn’t working but the decimal one is? Is there a way to use hex, or am I stuck with dec?
