Hi Guys,
1st of all I want to tell you that you got great community, you doing a great job!
2nd of all…I have a little problem that I’m sure that one of you can help me, I can’t save the IRule because i’m getting confused with the braces.
The IRule going like that:
if {[ HTTP::header exists “subscriberID” ]}
if {[matchclass [HTTP::header “subscriberID”] equals $::subscriberID]}
{pool AA-BB-Pool}
else { HTTP::respond 301 Location “http://XYZ.com” )
elseif {[matchclass [IP::client_addr] equals $::GGG]}
{ log local0. “Valid Source IP: [IP::client_addr] - forwarding traffic”
pool AA-BB-Pool}
else { HTTP::respond 301 Location “http://XYZ.com” } log local0. “INVALID Source IP: [IP::client_addr] - dropping traffic”
Can someone please help me?
Ido
Hello Ido, try this I think it’ll work (at least the iRule editor gives me no complaints!!):
if { [matchclass [HTTP::header “subscriberID”] equals $::subscriberID]} {
{pool AA-BB-Pool}
else { HTTP::respond 301 Location “http://XYZ.com” target=“_blank” rel=“nofollow”>http://XYZ.com" )
pool AA-BB-Pool}
else { HTTP::respond 301 Location “http://XYZ.com” target=“_blank” rel=“nofollow”>http://XYZ.com" } log local0. “INVALID Source IP: [IP::client_addr] - dropping traffic”
However, I don’t think you needed the first ‘if’ statement so I have removed it if {[ HTTP::header exists “subscriberID” ]} although one of the more experienced chaps may be able to guide you better on that. Let us know how you get on.
Hi There,
I have been told that I have to put this line in the begining,could someone please advise with the 1st line?
Thanks a lot for your help
Ido
I tryied this one:
if [ HTTP::header exists “subscriberID” ] } {
if [matchclass [HTTP::header “subscriberID”] equals $::subscriberID]} {
pool AA-BB-Pool} {
else {HTTP::respond 301 Location “http://XYZ.com” }
elseif { [matchclass [IP::client_addr] equals $::XXX] } {
pool AA-BB-Pool} {
log local0. “INVALID Source IP: [IP::client_addr] - dropping traffic” }
But I can’t save it because of brace’s problem.
Thanks a lot for your help.
Hi Ido,
the following is a valid rule, does this achieve your requirements?
if { [matchclass [HTTP::header exists “subscriberID”] equals $::subscriberID] } {
pool AA-BB-Pool
} elseif { [matchclass [IP::client_addr] equals $::XXX] } {
pool AA-BB-Pool
} else { HTTP::respond 301 Location “http://XYZ.com” }
I am afraid that I have little experience in the use of classes, but to my eye this looks like it should do the job - I’m sure someone will correct my inaccuracies!
As you can see i have removed a couple of lines in an effort to make the rule more efficient (the http::respond command is surely only needed if we don’t match the class for the subscriberID or the valid source IP?).
Thanks and good luck in your testing.
Please try to keep the stracture as it is, I need this Irule to be as I wrote.
Can you please help me?
I’m sorry for sounding bad and a pain in the ass.
But I really need it to work as it is.
Ido
Maybe something like this?
if {[HTTP::header exists "subscriberID"]}{
if {[matchclass [HTTP::header "subscriberID"] equals $::subscriberID]}{
pool AA-BB-Pool
HTTP::respond 301 Location "http://XYZ.com"
} elseif {[matchclass [IP::client_addr] equals $::XXX]}{
log local0. "Valid Source IP: [IP::client_addr] - forwarding traffic"
pool AA-BB-Pool
log local0. "INVALID Source IP: [IP::client_addr] - dropping traffic"
Note that you can use [ code ] [ /code ] tags (without the spaces) to preserve the indentation of your rule code. This makes it a lot easier to see the nesting of braces.
Aaron
