Header Insert of "http" or "https"
We’re going to implement a virtual server to handle HTTP and HTTPS requests. The developers need us to insert the protocol into the header. We’re still new to irules and I constantly fear performance issues because of irules. So I’m submitting what I have for some input.
 if {[TCP::local_port] equals 80}{
 HTTP::header insert X-Forwarded-Proto "http"
 log local0. "HTTP request from Client IP: [IP::client_addr] to [IP::local_addr]:[TCP::local_port]"
 } elseif {[TCP::local_port] equals 443}{
   HTTP::header insert X-Forwarded-Proto "https"
 log local0. "HTTPS request from Client IP: [IP::client_addr] to [IP::local_addr]:[TCP::local_port]"
Looks good from what I can tell. The only thing I would suggest is to check for the existence of the header. This way you are not always inserting for returning connections that already have it.
  if {([TCP::local_port] ==80) and !( [HTTP::header "X-Forwarded-Proto"] eq "http") }{
         } elseif {([TCP::local_port] ==443) and !( [HTTP::header "X-Forwarded-Proto"] eq "https") } {
I hope this helps
Bhattman
A client wouldn’t include a response header in a subsequent request, so the only time that header would exist is if the client injected it. You might actually want to remove any prior instance to ensure a malicious client couldn’t forge the header.
If the VIP is defined on port 0, you might also want to drop any non-80 or non-443 traffic. You can also do the check once in CLIENT_ACCEPTED instead of on each HTTP request:
when CLIENT_ACCEPTED {
     Check the requested port
    switch [TCP::local_port] {
       80 {
          set proto http
       443 {
          set proto https
       default {
           Drop the request
  drop
     Replace the X-Forwarded-Proto header if it exists
      If it does not exist, a new instance will be inserted
    HTTP::header replace X-Forwarded-Proto $proto
Aaron
Aaron,
I will be using one of your irules for the HTTPandHTTPS virtual server inconjunction with the XForwardedProto irule.
http://devcentral.f5.com/wiki/default.aspx/iRules/HttpHttpsSingleVirtualServer.html
Everything is good but Safari is doing something weird. It’s appending the url with :443 when it’s an http request, looks like this http://newsite.apa.org:443. Might be because the application is doing some switching between http and https. All the rest of the browsers are working w/o any problems.
You could add the XForwardedProto logic to the single VIP iRule by setting the proto variable to https in this section:
Request was to an HTTPS port, so do nothing for the clientside connection.
And setting it to http for in this section:
Request was to an HTTP port, not an HTTPS port, so disable client SSL profile if one is enabled on the VIP
I’d guess that Safari is getting a redirect to http://newsite.apa.org:443 and not actually generating that request itself. You could check this by logging the Location header in redirects or by using a browser plugin to log HTTP request/response headers and payloads. If it is coming from the app, you could add a check in the HTTP_RESPONSE event to look for [HTTP::is_redirect]==1 and then rewrite the Location header value using HTTP::header replace Location $new_location.
Aaron
Thank YOU kind sirs! I added the following to http_response and it resolved our Safari issue.
when HTTP_RESPONSE {
 if { [HTTP::header Location] starts_with "http://newsite.apa.org:443"} {
 log local0. "Location [HTTP::header Location]"
 HTTP::header replace Location "http://newsite.apa.org"
It would be more efficient to only check for the Location header on redirects. Also, if you want to preserve the URI in the redirect, you should use string map:
    if { [HTTP::is_redirect] and [HTTP::header Location] starts_with "http://newsite.apa.org:443"} {
       HTTP::header replace Location "[string map "http://newsite.apa.org:443 http://newsite.apa.org" [HTTP::header Location]]"
Aaron
This exactly what I did once the developers returned with an issue involving the need to preserve the URI.
Took a hint from another iRule I found on DevCentral http://devcentral.f5.com/wiki/default.aspx/iRules/RewriteHTTPRedirectPort.html.
I did something similar, except with the HTTP profile… i have one profile for non-ssl VS and one with ssl VS. Then each profile does a header insert that is basically SSL true or false, and the application reads this header.
I tried the above code, but for some reason, the Location is outputed as empty in the log.
Any ideas?
