GTM NAPTR irule
Hi
I am trying to create a dns NAPTR irule on my GTM (v11.0) but getting the following error:undefine procedure on the following lines:
line:13 DNS::answer insert $new_rr_1
line:22 DNS::return
And this is the dns record i am creating the irule for:
africacom2011.co.za.apn.epc.mnc010.mcc655.3gppnetwork.org. IN NAPTR 10 10 “a” “x-3gpp-pgw:x-s5-gtp” “” topoff.pgw-s5.tbggs2.area2.node.epc.mnc010.mcc655.3gppnetwork.org.
This is the irule rule:
when DNS_REQUEST {
if { [DNS::question type] eq “NAPTR” } {
switch -glob [string tolower [DNS::question name] ] {
www.africacom2011.co.za.apn.epc.mnc010.mcc655.3gppnetwork.org {
set new_rr_1 [DNS::rr "www.africacom2011.co.za.apn.epc.mnc010.mcc655.3gppnetwork.org. IN NAPTR 10 10
\“s\” \“x-3gpp-pgw:x-s5-gtp\” \“\” topoff.pgw-s5.tbggs2.area2.node.epc.mnc010.mcc655.3gppnetwork.org.famge1.area1.node.epc.mnc010.mcc655.3gppnetwork.org"]
DNS::header aa 1
DNS::return
hello,
every body, do you have some thing news about the issue comment by Chrism. because I have the same
behavior.
01070151:3: Rule [/Common/NAPTR_TEST] error:
line 13: [undefined procedure: DNS::answer] [DNS::answer insert $new_rr_1 ]
line 22: [undefined procedure: DNS::return] [DNS::return]
