We have recently setup VIP for ftp connections through F5. We are having issues when user is trying to access ftp using filezilla client (in both active and passive modes) . Is it possible that F5 is not able to handle connections coming from filezilla? Please help me in understanding this.
Yes Brad, Session is timing out and I have tried allowing data-port 20 and 0. Both gave me same results. virtual config ltm virtual vs_test01_ { auto-lasthop enabled destination x.x.x.2:ftp ip-protocol tcp mask 255.255.255.255 partition Corp_Non-prod pool pl_test01 profiles { /Common/tcp { } ftp_test { } } source 0.0.0.0/0 source-address-translation { type automap } vs-index 92 } Thanks, Sekhar
What is timing out exactly? The opening of the control channel? The opening of the data channel? or is it timing out while a file is being transferred?
after initializing tls command on filezilla client time outs intially it retries again and fails.. this is the output on zilla client Status:Connecting to x.x.x.2:21… Status:Connection established, waiting for welcome message… Status:Initializing TLS… Error:Connection timed out after 20 seconds of inactivity Error:Could not connect to server Status:Waiting to retry… Status:Connecting to x.x.x.2:21… Status:Connection established, waiting for welcome message… Response:220-Welcome to FTP! Response:220 CrushFTP Server Ready! Command:AUTH TLS Response:234 Changing to secure mode… Status:Initializing TLS… Error:Connection timed out after 20 seconds of inactivity Error:Could not connect to server Status:Disconnected from server Thanks, Sekhar
