Hi Forum,
I would like to create a VIP for a FTP Server with TLS.
Behind our BIG-IP LTM (Version 15.1.51) I have installed a Server with vsftp.
When I connect directly to this Server I have no problem to connect with TLS.
If I use the Public address (mean I come from outside via F5) I can connect but then I get an error about the “Data Port”
If I allow all Ports on the VIP and Pool, everything is fine, but this is not an option for me ![]()
Does anybody has a hint for me. I found nothing here in this forum about FTP with TLS.
Here are my configs
ltm virtual /IN_FTP {
description "FTP Server"
destination 555.666.777.888:21
ip-protocol tcp
last-modified-time 2022-07-06:19:11:46
mask 255.255.255.255
pool /FTP
profiles {
/Common/ftp { }
/Common/tcp { }
serverssl-use-sni disabled
source 0.0.0.0/0
source-address-translation {
type automap
translate-address enabled
translate-port enabled
vlans {
/Common/epfrontyard
/Common/epproduction
/Common/grenznetz_web_1
/Common/grenznetz_web_2
vlans-enabled
ltm pool FTP {
description "FTP server "
members {
/ftp1:21 {
address 111.222.333.444
monitor /Common/gateway_icmp
