I have a VS, snat automap, and using fqdn member that resolve dns in IP (10.1.1.x). Can I using the fqdn member (10.1.1.x), as IP VS in the same box or same ip management?? it can works ? If can’nt, what is the reason ??
Are you saying you want send traffic from one virtual server to a FQDN pool member, that happens to also be a virtual server on the same BIG-IP?
If so, there is a supported way to do that called Vip targeting Vip, and you use an iRule or a Local Traffic Policy to do that.
I’m not sure I understand what your goals are, and how this configuration is serving them. Can you take a step back and state your goals for each VIP and what traffic from what source needs to be managed?
