hi, i am have a request from costumer,which i must to insert 2 pool fqdn in 1 VS, so can it i do ? because in VS can insert 1 rewrite profil for rewrite FQDN to IP ,
thanks
thanks
If I am correctly understanding your question, you want to have two FQDN based pools behind single vServer.
If that’s so, you can achieve it using iRULE OR LTM POLICY. With the help of iRULE or LTM POLICY, request can be point to the desired pool based on the different conditions eg URL host, URI path etc.
thanks you for your solustion sir,Do you have irules or article for this case?
Below posts will help you with the same.
If you still need any additional help on it, please feel free to ask.
https://community.f5.com/t5/technical-forum/virtual-server-with-two-sites-but-same-ip/td-p/299842
https://community.f5.com/t5/technical-forum/multiple-web-applications-behind-single-vs/td-p/235909
