F5OS rSeries 5600 LAG.
Configure a LAG for ha-interconnect between two F5OS rSeries, is it require to associate a vlan to the lag or can it be configure without a vlan.
How does the LAG works behind the chassis. Can one lag be presented to multiple tenants to be use for ha-interconnect?
Hi @fwwescom ,
the HA Interconnect requires a VLAN ID to be assigned to the LAG, but can be untagged.
The LAG can be assigned to multiple tenants.
How the LAG works behind the scenes is a very broad question, the answer is far too long for this forum.
And, this is just my opinion, a LAG for HA Interconnect is overkill. For a box to box interconnect, a single Interface to Interface will do.
Cheers
Daniel
EDIT for clarification: A VLAN can be assigned to multiple tenants, not the LAG itself.
VLANs are assigned to a LAG and also to a BIG-IP tenant.
