So i get this error when I’m trying to add trunk to the ha vlan that i created-
ERROR: Unable to find interface object for configured trunk member 3.0
What does this mean?
When i look under the interfaces for the tenant (17.5.0) i do not see the actual interfaces which are supposed to be 1.0, 2.0, 3.0 - - - - 10.0 instead i only see 0.1, 0.2, 0.3 - - 0.6 is that the reason why it shows the error?
Also why does it even show 0.1, 0.2 - - - 0.6 instead of the 1.0, 2.0, 3.0, - - - - 10.0??
This makes no sense to me.
Thank You
The tenant is actually KVM VM and you should find the real interfaces under the r5600 F5OS and create LAG as that is the new name
See:
rSeries Networking
Similar issue here as well.
We have a r5600 with F5OS 1.8 and tenants running on 17.5.0.
We created a LAG with interfaces 3.0 & 7.0 and 4.0 & 8.0 (to share the internal pipelines). And we created also some VLANs and assigned them to the LAGs as required.
Now within the tenants we see the VLANs and also the trunks. But the VLANs do NOT show any reference in the “Tagged Interface” column:
And also for the trunks the “Capacity” column shows 0:
Is this really normal behavior or do I miss something on F5OS-level?
If I try then to assign the VLAN to the trunk within the tenant configuration I also get the same error message.
Then I tried if ping is maybe working without any further configurations within the tenant, but this is also not working.
Therefor something seems to be still wrong or missing.
Configuration of F5OS looks like this:
Are there any other/additional information available, how VLAN and Trunk/LAG configuration is working and shared between F5OS and tenants?
Thank you!
Regards Stefan
Within the trunk details the correct physical interfaces from F5OS will be displayed:
But on the Interface list they are missing:
That’s why also the error message makes (theoretically) sense:
So what’s going wrong internal here???
Thank you!
Regards,
Stefan
Ok, issue is solved on our side.
There was a mismatch of the mapping between the switch ports and the assigned VLANs.
Once corrected ping is working.
This means there is NO additional configuration required in regards to trunks or VLANs within the tenant. Only the IP-addresses must be created and assigned to the VLANs. Everything else is handled and managed via F5OS.
But can still someone confirm the look and feel of the Interface and Trunks menu within the tenant? From an operational point of view this doesn’t feels intuitive or is this something “normal” with virtualization? Maybe this can be optimized in next versions?
Thank you!
Regards,
Stefan
The issue/error message is back again
We need to setup different VLANs in dedicated partitions/Route Domains.
Therefor we created first the VLANs on F5OS and assigned them to the tenant.
Then these VLANs will correctly shown within the tenant, but by default in the Common partition.
We deleted the VLAN in Common, switched to the required partition and tried to recreate it there as well using the exact name like in F5OS.
But then we get again the ERROR: Unable to find interface object for configured trunk member 3.0
Where is this coming from and how can this be fixed?
Thank you!
Regards,
Stefan
Hello Stefan, how did you manage to fix this?
I have the same issue..
Edit: nevermind, it was a trunking issue for me.
When recreating the VLAN in the required partition/route domain, you may not select any interfaces!!!
Just enter the name and VLAN-ID. Everything else will be handled from the underlying F5OS.
I hope this will be optimized in future releases, because I would expect that settings, which needs to be specified only on F5OS-layer, will NOT be visible on tenant-layer.
Regards,
Stefan
