F5 SSL VPN for 64bit Linux
Does someone know if there is a way to connect to F5 SSL VPN from 64bit linux desktop?
Automatic install of plugin for firefox didn’t work.
I was able to install it manually using “nspluginwrapper” but I think there is a problem with “other components”.
I downloaded them and untarred as specified but it doesn’t connect anyway. I even tried wrapping svpn with a linux32 call but still no luck.
Thanks in advance
P.S. I’m using Kubuntu 6.10 64bit
Two (untested) ideas:
1) Launch firefox under the linux32 wrapper, eg: linux32 firefox
or
2) Install 32bit version of firefox
--JST
Thank you, I’ll try that.
It does not work for me… ubuntu 8.04 64bits & Firepass 6.0.2
It is also not working for me. Using Ubuntu 8.04 with Firefox 3 Beta 5. Where can I download the Linux client software for network connectivity?
Same here … BtW, I got the 32b client *almost* working (“Status: Connected” + interface ppp0 up + routing tables OK), but couldn’t connect my ssh to the remote host trough this connection (in fact, the remote serveur refuses the connection with “Authentication protocol mismatch” although I forced V2) … it works with the windows plugin client.
… Any idea ?
I got it working on Ubuntu Gutsy Gibbon 7.10 with the process below. Summary and other resources available at http://ubuntuforums.org/showthread.php?p=1174435. (I’m not sure which actual packages you will need, but these are the names of the .deb files I used for Ubuntu 7.10).
download & install:
http://home.comcast.net/~ubuntume/ia32-lib-firefox-amd64.deb
run:
sudo apt-get -y install ia32-libs gsfonts alsa-oss
sudo apt-get -y install ia32-libs-gtk lib32asound2 lib32ncurses5 ia32-libs-sdl
sudo apt-get -y --force-yes install ia32-sun-java6-bin
download & install:
http://mirrors.kernel.org/ubuntu/pool/main/l/linux32/linux32\_1-3\_amd64.deb
http://mirrors.kernel.org/ubuntu/pool/main/g/gsfonts-x11/gsfonts-x11\_0.17ubuntu4\_all.deb
http://home.comcast.net/~ubuntume/ia32-alsa-oss\_1.0.10-1\_amd64.deb
download & install:
http://home.comcast.net/~ubuntume/icecat-2.0.0.11-ubuntu\_7.10-8.04\_amd64.deb
Then, install the F5 plugin inside Icecat.
The reason I chose to use Icecat is that it will not interfere with any 64-bit or off-version plugins that you may have installed in your normal Firefox installation. I was unable to install both FireBug and the VPN plugin in the same browser, and it seems that firefox32, firefox32-3, and firefox64 all use the same plugins.
It is probably possible to separate these installations using some config tweaks, but I thought it would be more reliable, reproducible, and maintainable to use browsers that by default use separate plugin directories.
Good luck!
