F5 LTM - cipher logging
Hello,
I am trying to log all ciphers using on an LTM, I believe it is done through an Irule but need help with the full string.
Are you trying to log all ciphers used during SSL connections?
Think you can use something like the SSL::cipher iRule command: iRules SSL::cipher
    log local0. "[SSL::cipher name], [SSL::cipher version], [SSL::cipher bits]
Not sure if HTTP_REQUEST is the best event to use though as will log every request when you likely only want to log once per SSL session.
  1. Have you applied the iRule to the VIP in question?
  2. Do you have a Client SSL profile applied to the VIP in question? If your back-end server ssl based then you have to apply server side ssl profile too for both side ssl offload.
    If there is no SSL profile applied, big-ip will not do ssl offload and you will not be able to identify negotiated cipher suit
