I am a new user of F5, and DevCentral.Earlier, was having problem with management port. The issue is fixed.
Kindly advise if the following is post on wrong section
Currently, I am working on configure F5 1500 Link Controller, BIG-IP 9.3.1 as a simple outbound loand balancer.
Following are configured.
1. Management IP - 172.168.1.22/16
2. Self IP (internal) - 10.160.1.17/28(vlan 4094, untagged at int 1.1) - allowed default
3. Self IP (external) - 10.160.1.5/29 (vlan 4093, untagged at int 1.3) - allowed default
4. Pool (default_gateway_poll) - 10.160.1.1/29 (router1 int 0/0)
- 10.160.1.2/29 (router2 int 0/1)
Configured with RR
Physical connection is the following.
Single L2 switch (no vlan)
connected with the following
F5 Int 1.1
F5 Int 1.3
router1 int 0/0 (10.160.1.1/29)
router2 int 0/0 (10.160.1.2/29)
laptop (internal network, 10.160.1.22/28 g/w 10.160.1.17/28 - F5 self IP internal)
The following is already achieved.
1. The gateway pool is active (default_gateway_pool up)
2. Self IP internal is active (able to ping from laptop)
3. Configured Wildcard (0.0.0.0:0), associate to default_gateway_pool)
4. Configured SNAT using Automap (but not sure how to associate it)
Currently, I can’t ping to Self IP external. (time out) and also all my default_gateway_pool IP from my laptop.
Seems that F5 is connected to the external, and internal.
But is not interconnecting between internal and external
May I know what is the proper way to configure the mentioned?
Any configuration guide/walkthrough that would be helpful for a complete newbies?
