F5 iRule Geolocation restriction
Hello,
I want to know how I can restrict the access to specific one country only via iRule.
For example: allow only users to access from “US” and block all other countries.
I would make sure the LTM is updated with the latest GeoLocationUpdates from F5. Otherwise you will likely block valid US addresses.
Here is one very simple way to do this:
# Block_non_US_IP
# iRule to drop traffic that is not from US addresses
when CLIENT_ACCEPTED {
if { not [whereis [IP::client_addr] continent country] == “NA US” } {
log local0. “Connection from [IP::client_addr] [whereis [IP::client_addr] continent country] to [virtual name] [IP::local_addr] : Blocked.”
drop
Hello David,
Thank you for your reply.
Just to clarify more, I’am using F5 DNS/LTM and I will apply the iRule on the VS.
Also, I prefer to block the traffic when TCP-SYN or UDP packet come from non-US country. I got iRule from clouddocs.f5 that may will work
when FLOW_INIT {
set ipaddr [IP::client_addr]
set locale [whereis $ipaddr country]
log local0. “IP Address/Counry $ipaddr/$locale”
switch $locale {
“US” { return }
default { ACL::action drop }
That iRule might need AFM license.
when FLOW_INIT {
    # Drop everything except US
    if { ! ([whereis [IP::client_addr] country] equals "US") } {
        log -noname local0. "Dropping connection from [IP::client_addr]/[whereis [IP::client_addr] state country continent ]"
        drop
AFM not required.
Hello  David_Gill,
I tested the iRule which I mentioned early and it worked fine.
Is there any difference with the one which you mentioned?
Functionally they do the same thing however ACL::action drop requires AFM whereas drop on its own does not which means the snippet works for a larger audience. Switch is generally used when making more than one comparison (as shown at https://clouddocs.f5.com/api/irules/ACL__action.html) which is why I used a single if statement. There is no need to define any variables either. That said, in both cases the end result is the same.
