Recieving the following error when trying to deploy an AWS BIGIP instance using a Terraform templatefile() function to pass variables to cloud-init template file,
tmos_do_only_wait - DEBUG - f5-declarative-onboarding error 422 - {u’message’: u’request failed with null exception’, u’code’: 422, u’referer’: u’Unknown’, u’restOperationId’: 6674184, u’kind’: u’:resterrorresponse’}
This errors occurs after the icontrollx packages (DO, AS3) are installed. When I use static values along with the file() function in the user_data argument the BIGIP has no issues accepting the configuration. I’ve verified my configs and compared it to examples provided in GitHub - F5Networks/terraform-aws-bigip-module: Terraform module for Deploying BIG-IP in AWS · GitHub with no success.
Code below
~variables.tf~
variable "name_servers" { default = "" }
variable "ltm_eth0_sg_id" { default = "" }
variable "ltm_eth0_subnet_id" { default = "" }
variable "ltm_eth0_subnet_cidr_block" { default = "" }
variable "ltm_eth1_sg_id" { default = "" }
variable "ltm_eth1_subnet_id" { default = "" }
variable "ltm_eth1_subnet_cidr_block" { default = "" }
variable "ltm_eth2_sg_id" { default = "" }
variable "ltm_eth2_subnet_id" { default = "" }
variable "ltm_eth2_subnet_cidr_block" { default = "" }
variable "ltm_eth3_sg_id" { default = "" }
variable "ltm_eth3_subnet_id" { default = "" }
variable "ltm_eth3_subnet_cidr_block" { default = "" }
variable "ltm_eth4_sg_id" { default = "" }
variable "ltm_eth4_subnet_id" { default = "" }
variable "ltm_eth4_subnet_cidr_block" { default = "" }
variable "ltm_eth5_sg_id" { default = "" }
variable "ltm_eth5_subnet_id" { default = "" }
variable "ltm_eth5_subnet_cidr_block" { default = "" }
variable "ltm_eth6_sg_id" { default = "" }
variable "ltm_eth6_subnet_id" { default = "" }
variable "ltm_eth6_subnet_cidr_block" { default = "" }
variable "ltm_eth7_sg_id" { default = "" }
variable "ltm_eth7_subnet_id" { default = "" }
variable "ltm_eth7_subnet_cidr_block" { default = "" }
variable "ltm2_eth0_intf_ip" { default = "" }
variable "ltm2_eth1_intf_ip" { default = "" }
variable "ltm2_eth2_intf_ip" { default = "" }
variable "ltm2_eth3_intf_ip" { default = "" }
variable "ltm2_eth4_intf_ip" { default = "" }
variable "ltm2_eth5_intf_ip" { default = "" }
variable "ltm2_eth6_intf_ip" { default = "" }
variable "ltm2_eth7_intf_ip" { default = "" }
~main.tf~
module "ltm" {
name_servers = ["169.254.169.253", "8.8.8.8"]
ltm_eth0_sg_id = module.security_groups.ltm_mgmt_security_group_id
ltm_eth0_subnet_id = module.subnet.ltm_gtm_mgmt_subnet_id
ltm_eth0_subnet_cidr_block = module.subnet.ltm_gtm_mgmt_subnet_cidr_block
ltm_eth1_sg_id = module.security_groups.ltm_routing_security_group_id
ltm_eth1_subnet_id = module.subnet.ltm_gtm_routing_subnet_id
ltm_eth1_subnet_cidr_block = module.subnet.ltm_gtm_routing_subnet_cidr_block
ltm_eth2_sg_id = module.security_groups.ltm_external_security_group_id
ltm_eth2_subnet_id = module.subnet.ltm_ext_vip1_subnet_id
ltm_eth2_subnet_cidr_block = module.subnet.ltm_ext_vip1_subnet_cidr_block
ltm_eth3_sg_id = module.security_groups.ltm_external_security_group_id
ltm_eth3_subnet_id = module.subnet.ltm_ext_vip2_subnet_id
ltm_eth3_subnet_cidr_block = module.subnet.ltm_ext_vip2_subnet_cidr_block
ltm_eth4_sg_id = module.security_groups.ltm_external_security_group_id
ltm_eth4_subnet_id = module.subnet.ltm_ext_vip3_subnet_id
ltm_eth4_subnet_cidr_block = module.subnet.ltm_ext_vip3_subnet_cidr_block
ltm_eth5_sg_id = module.security_groups.ltm_internal_security_group_id
ltm_eth5_subnet_id = module.subnet.ltm_int_vip1_subnet_id
ltm_eth5_subnet_cidr_block = module.subnet.ltm_int_vip1_subnet_cidr_block
ltm_eth6_sg_id = module.security_groups.ltm_internal_security_group_id
ltm_eth6_subnet_id = module.subnet.ltm_int_vip2_subnet_id
ltm_eth6_subnet_cidr_block = module.subnet.ltm_int_vip2_subnet_cidr_block
ltm_eth7_sg_id = module.security_groups.ltm_internal_security_group_id
ltm_eth7_subnet_id = module.subnet.ltm_int_vip3_subnet_id
ltm_eth7_subnet_cidr_block = module.subnet.ltm_int_vip3_subnet_cidr_block
ltm2_eth0_intf_ip = ["10.169.96.7"]
ltm2_eth1_intf_ip = ["10.169.96.72"]
ltm2_eth2_intf_ip = ["10.169.97.40"]
ltm2_eth3_intf_ip = ["10.169.98.40"]
ltm2_eth4_intf_ip = ["10.169.99.40"]
ltm2_eth5_intf_ip = ["10.169.100.40"]
ltm2_eth6_intf_ip = ["10.169.101.40"]
ltm2_eth7_intf_ip = ["10.169.102.40"]
~ltm2_main.tf~
resource "aws_network_interface" "ltm2_eth0_intf" {
subnet_id = var.ltm_eth0_subnet_id
private_ips = var.ltm2_eth0_intf_ip
security_groups = [var.ltm_eth0_sg_id]
source_dest_check = "true"
tags = {
Name = "LTM2:ETH0"
resource "aws_network_interface" "ltm2_eth1_intf" {
subnet_id = var.ltm_eth1_subnet_id
private_ips = var.ltm2_eth1_intf_ip
security_groups = [var.ltm_eth1_sg_id]
tags = {
Name = "LTM2:ETH1"
resource "aws_network_interface" "ltm2_eth2_intf" {
subnet_id = var.ltm_eth2_subnet_id
private_ips = var.ltm2_eth2_intf_ip
security_groups = [var.ltm_eth2_sg_id]
tags = {
Name = "LTM2:ETH2"
resource "aws_network_interface" "ltm2_eth3_intf" {
subnet_id = var.ltm_eth3_subnet_id
private_ips = var.ltm2_eth3_intf_ip
security_groups = [var.ltm_eth3_sg_id]
tags = {
Name = "LTM2:ETH3"
resource "aws_network_interface" "ltm2_eth4_intf" {
subnet_id = var.ltm_eth4_subnet_id
private_ips = var.ltm2_eth4_intf_ip
security_groups = [var.ltm_eth4_sg_id]
tags = {
Name = "LTM2:ETH4"
resource "aws_network_interface" "ltm2_eth5_intf" {
subnet_id = var.ltm_eth5_subnet_id
private_ips = var.ltm2_eth5_intf_ip
security_groups = [var.ltm_eth5_sg_id]
tags = {
Name = "LTM2:ETH5"
resource "aws_network_interface" "ltm2_eth6_intf" {
subnet_id = var.ltm_eth6_subnet_id
private_ips = var.ltm2_eth6_intf_ip
security_groups = [var.ltm_eth6_sg_id]
tags = {
Name = "LTM2:ETH6"
resource "aws_network_interface" "ltm2_eth7_intf" {
subnet_id = var.ltm_eth7_subnet_id
private_ips = var.ltm2_eth7_intf_ip
security_groups = [var.ltm_eth7_sg_id]
tags = {
Name = "LTM2:ETH7"
resource "aws_instance" "ltm2" {
ami = "ami-07cda73ac7991dfc8"
instance_type = "c4.8xlarge"
key_name = "ltm2-key"
disable_api_termination = "false"
ebs_optimized = "false"
root_block_device {
#device_name = "/dev/xvda"
volume_type = "standard"
volume_size = "142"
ebs_block_device {
device_name = "/dev/xvdb"
volume_size = "20"
network_interface {
network_interface_id = aws_network_interface.ltm2_eth0_intf[0].id
device_index = 0
network_interface {
network_interface_id = aws_network_interface.ltm2_eth1_intf[0].id
device_index = 1
network_interface {
network_interface_id = aws_network_interface.ltm2_eth2_intf[0].id
device_index = 2
network_interface {
network_interface_id = aws_network_interface.ltm2_eth3_intf[0].id
device_index = 3
network_interface {
network_interface_id = aws_network_interface.ltm2_eth4_intf[0].id
device_index = 4
network_interface {
network_interface_id = aws_network_interface.ltm2_eth5_intf[0].id
device_index = 5
network_interface {
network_interface_id = aws_network_interface.ltm2_eth6_intf[0].id
device_index = 6
network_interface {
network_interface_id = aws_network_interface.ltm2_eth7_intf[0].id
device_index = 7
user_data = templatefile("${path.module}/ltm.tpl", {
hostname = "ltm2-lab"
name_server1 = var.name_servers[0]
name_server2 = var.name_servers[1]
ltm_ext_vips1_ip = var.ltm2_eth2_intf_ip[0]
ltm_ext_vips2_ip = var.ltm2_eth3_intf_ip[0]
ltm_ext_vips3_ip = var.ltm2_eth4_intf_ip[0]
ltm_int_vips1_ip = var.ltm2_eth5_intf_ip[0]
ltm_int_vips2_ip = var.ltm2_eth6_intf_ip[0]
ltm_int_vips3_ip = var.ltm2_eth7_intf_ip[0]
ltm_traffic_ip = var.ltm2_eth1_intf_ip[0]
admin_pwd = "Password1234"
tags = {
Name = "ltm2-lab"
~ltm.tpl~
#cloud-config
tmos_declared:
enabled: true
icontrollx_trusted_sources: false
icontrollx_package_urls:
- "https://github.com/F5Networks/f5-declarative-onboarding/releases/download/v1.37.0/f5-declarative-onboarding-1.37.0-3.noarch.rpm"
- "https://github.com/F5Networks/f5-appsvcs-extension/releases/download/v3.44.0/f5-appsvcs-3.44.0-3.noarch.rpm"
do_declaration:
schemaVersion: 1.0.0
class: Device
async: true
label: Cloudinit Onboarding
Common:
class: Tenant
provisioningLevels:
class: Provision
ltm: dedicated
System:
class: System
hostname: ${hostname}
mgmtDhcpEnabled: false
autoCheck: false
autoPhonehome: true
dnsServers:
class: DNS
nameServers:
- ${name_server1}
- ${name_server2}
search:
- ops.sfdc.net
ntpServers:
class: NTP
servers:
- ${name_server1}
- ${name_server2}
EXT-VIPS-1-VLAN:
class: VLAN
tag: 102
interfaces:
- name: "1.2"
SelfIp_EXT-VIPS-1:
class: SelfIp
address: ${ltm_ext_vips1_ip}/24
vlan: EXT-VIPS-1-VLAN
trafficGroup: traffic-group-local-only
allowService: none
EXT-VIPS-2-VLAN:
class: VLAN
tag: 103
interfaces:
- name: "1.3"
SelfIp_EXT-VIPS-2:
class: SelfIp
address: ${ltm_ext_vips2_ip}/24
vlan: EXT-VIPS-2-VLAN
allowService: none
EXT-VIPS-3-VLAN:
class: VLAN
tag: 104
interfaces:
- name: "1.4"
SelfIp_EXT-VIPS-3:
class: SelfIp
address: ${ltm_ext_vips3_ip}/24
vlan: EXT-VIPS-3-VLAN
allowService: none
INT-VIPS-1-VLAN:
class: VLAN
tag: 105
interfaces:
- name: "1.5"
SelfIp_INT-VIPS-1:
class: SelfIp
address: ${ltm_int_vips1_ip}/24
vlan: INT-VIPS-1-VLAN
allowService: none
INT-VIPS-2-VLAN:
class: VLAN
tag: 106
interfaces:
- name: "1.6"
SelfIp_INT-VIPS-2:
class: SelfIp
address: ${ltm_int_vips2_ip}/24
vlan: INT-VIPS-2-VLAN
allowService: none
INT-VIPS-3-VLAN:
class: VLAN
tag: 107
interfaces:
- name: "1.7"
SelfIp_INT-VIPS-3:
class: SelfIp
address: ${ltm_int_vips3_ip}/24
vlan: INT-VIPS-3-VLAN
allowService: none
TRAFFIC-VLAN:
class: VLAN
tag: 101
interfaces:
- name: "1.1"
SelfIp_TRAFFIC:
class: SelfIp
address: ${ltm_traffic_ip}/27
vlan: TRAFFIC-VLAN
allowService: default
chpasswd:
list: |
admin:${admin_pwd}
expire: False
