Hello friends,
Please, could you help me to understand how to integrate a Radius server with APM?
Currently, I have a VPN based on another devide which communicates to a Radius to authenticate users based on username, password and a Token RSA. I have disconnected such device and connected the LTM+APM appliance with the same IP. So, the Radius will get requests going from the same Ip address which was declared as client of the radius. The communication fails and I don’t know why. I have put the correct shared key. The following capture shows that the connection is established (10.1.199.124 is the Self IP of the F5; 10.1.218.62 is the radius), but at the final stage the radius server reject the request
Please, could you tell me if I need to perform the following tasks?
Please, I will appreciate your prompt help.
Thanks and regards
Omar
