Disabling Ciphers
Guys,
We are deploying Skype at work. The Skype team would like me to disable the “Weak” Ciphers and only enable the others. I know you can disable / enable them in the clientssl profile under Advanced. But, what is the correct context to do this?
Thank You
Here is the list
TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA384 (0xc028) ECDH secp384r1 (eq. 7680 bits RSA) FS256 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA256 (0xc027) ECDH secp384r1 (eq. 7680 bits RSA) FS128 TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA (0xc014) ECDH secp384r1 (eq. 7680 bits RSA) FS256 TLS_ECDHE_RSA_WITH_AES_128_CBC_SHA (0xc013) ECDH secp256r1 (eq. 3072 bits RSA) FS128
TLS_RSA_WITH_AES_256_CBC_SHA256 (0x3d) WEAK256
TLS_RSA_WITH_AES_128_CBC_SHA256 (0x3c) WEAK128
TLS_RSA_WITH_AES_256_CBC_SHA (0x35) WEAK256
TLS_RSA_WITH_AES_128_CBC_SHA (0x2f) WEAK128
TLS_RSA_WITH_3DES_EDE_CBC_SHA (0xa) WEAK112
TLS 1.1 (suites in server-preferred order)
TLS 1.0 (suites in server-preferred order)
Yes, you need to set this in the clientSSL profile applied to the virtual.
You can also create a clientssl profile that specifies your selected ciphers, and use that profile as the parent profile for the Virtual server specific clientssl profiles. Then if you need to change the ciphers set for all your virtuals, you can update the parent and change all the child profiles at once.
Do NOT modify the default clientSSL profile
@Rob, Do you want to disable only Weak cipher, which you have pasted in Question section. Let us know.
I want to disable only the ciphers I noted as weak
Disable below cipher in-order to eliminate weak cipher list. I have tested in v12 and all weak cipher gone. Suggest you to test in LAB environment and share feedback. Most important thing, don’t play with default
client-ssl
profile which has pointed by @SBlakely
Find the weak cipher list as per above question .
AES256-SHA256
    AES128-SHA256
    AES256-SHA
    AES128-SHA
    DES-CBC3-SHA
TLS 1.1 (Weak suites in server-preferred order)
AES256-SHA
    AES128-SHA
    DES-CBC3-SHA
TLS 1.0 (Weak suites in server-preferred order)
AES256-SHA
    AES128-SHA
    DES-CBC3-SHA
My Apologies for being dumb - So, I copy the above list in the “Ciphers” section in the clientssl profile that I created? Anything else? What am I missing?
Thank you for your help
When I try this I’m getting an error
01070312:3: Invalid keyword ’ aes256-sha256’ in ciphers list for profile /Common/clientssl-test-cyphers
Cipher List to insert.
AES256-SHA256: AES128-SHA256: AES256-SHA: AES128-SHA: DES-CBC3-SHA: AES256-SHA: AES128-SHA: DES-CBC3-SHA: AES256-SHA: AES128-SHA: DES-CBC3-SHA:
Try this
DEFAULT:ECDHE:!RSA:!DHE:!3DES
Thank you - You are a genius!
