Hello,
I have built (copied) the following irule and am having trouble making it do what i want… I want a url like http://view.usg.edu/dvw5 to go directly to the web root on the machine named dvw5 (or http://10.1.1.5/ in the class below).
here’s the class:
class db300_direct {
dvw5 10.1.1.5:8000
dvw6 10.1.1.6:8000
and here’s the irule:
if { [HTTP::uri] starts_with “/dv” } {
set urimbr [substr [HTTP::uri] 1 “/”]
log local0. $urimbr
set node [findclass $urimbr $::db300_direct " "]
log local0. $node
pool VistaWebApps member $node
Now according to my log, $urimbr is what i expect, and $node is what i expect. I get a 404 error from the machine. When i captured the packets and looked at the trace, i see that the packet is in fact getting directed to the $node as i expect, but the thing i don’t understand, (and haven’t been able to figure out with much trial and error) is that it is being directed to http://10.1.1.5/dvw5 and since there is no directory dvw5 under the web root, the 404 error is understandable.
The thing is, i don’t want the request to go to http://10.1.1.5/dvw5 -- i want it to go to http://10.1.1.5/
If someone would be so kind as to help me understand what i am doing wrong i would be most gratefull.
Thanks in advance!
