need to redirect incoming connections to different ip addresses based on url info and data groups
Could you supply a bit more information? For instance, what do the requests look like? Do you need to redirect based on the IP-address or the path?
Apologies the dev central mail got quarantined, hence the slowness of response I am trying to do the following
Translation of URL containing a store Id to private IP inside our network, ie. the Server will send a request to the F5 Vip, within the url will be the store ID, I then want the F5 to look up the stor ID and forward the request to the correct store IP The URL will look like → https://10.226.1.10/rest/of/url → https://10.226.1.20/rest/of/url There will be approx 200 stores
Store Id Store private IP 0001 10.226.1.10 0002 10.226.1.20 0003 10.226.1.30 etc
e.g.
configuration
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.24.10:80
ip-protocol tcp
mask 255.255.255.255
profiles {
http { }
tcp { }
rules {
qux
source 0.0.0.0/0
source-address-translation {
type automap
vs-index 2
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm rule qux
ltm rule qux {
set storeid [URI::path [HTTP::uri] 1 1]
if { [class match -- $storeid equals storeid_to_ip] } {
set ip [class match -value -- $storeid equals storeid_to_ip]
HTTP::header replace Host $ip
HTTP::uri [string map [list $storeid /] [HTTP::uri]]
node $ip
root@(ve11a)(cfg-sync In Sync)(Active)(/Common)(tmos) list ltm data-group internal storeid_to_ip
ltm data-group internal storeid_to_ip {
records {
/0001/ {
data 200.200.200.101
/0002/ {
data 200.200.200.111
type string
trace
[root@ve11a:Active:In Sync] config ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.24.1(36489) <-> 172.28.24.10(80)
1416743408.3850 (0.0015) C>S
GET /0001/rest/of/url HTTP/1.1
User-Agent: curl/7.29.0
Accept: */*
Host: f5-retail
New TCP connection 2: 200.200.200.11(36489) <-> 200.200.200.101(80)
1416743408.3868 (0.0004) C>S
GET /rest/of/url HTTP/1.1
Accept: */*
Host: 200.200.200.101
e.g.
configuration
ltm virtual bar {
ip-protocol tcp
profiles {
http { }
tcp { }
rules {
qux
source 0.0.0.0/0
type automap
vs-index 2
ltm rule qux {
node $ip
records {
/0001/ {
/0002/ {
type string
trace
Accept: */*
Host: f5-retail
Accept: */*
i used http because it is easier to trace.
Hi Thanks for this I thought I had this working but actually although the script runs It then uses the associated pool and load balances the connections in the normal manner I notice that you do not have a pool associated with your virtual server, however I am unable to create a virtual server without a pool. I have added the ltm virtual f5-retail { description “Broker” destination 10.127.10.144:http ip-protocol tcp mask 255.255.255.255 pool Retail profiles { http { } tcp { } } rules { qux } source 0.0.0.0/0 source-address-translation { type automap } vlans { VIP-VLAN } vlans-enabled }
why not?
can you try to add oneconnect profile and see if it makes any difference?
sol7208: Overview of the OneConnect profile
“>https://support.f5.com/kb/en-us/solutions/public/7000/200/sol7208.html” target=“_blank”>">https://support.f5.com/kb/en-us/solutions/public/7000/200/sol7208.html
Hi
Ok I will have to come clean I had the the mappings in the data group as “1234” instead of “/1234/” So the script ran and of course never found a resolution. As you had made this clear in your config above it was a stupid mistake.
Interestingly I am now able to remove the pool ?? Although I have rewritten the script to check the pool as I think this may be a better option for us.
Many thanks for your help without which I probably would still be running around in circles
