Delete URI after pool is selected - iRule
Hello All,
So I was asked to come up with an iRule to accomplish below- URI based pool+port selection, delete the uri and send it to the selected pool+port, subsequent connections should also go to the same pool.
Let me elaborate with examples
app.example.com/apple/ui - port 9887 (apple_9887_pool)
app.example.com/android/ui - port 7889 (andriod_7889_pool)
So once based on uri the pool is selected apple_9887_pool for /apple/ui and andriod_7889_pool for /andriod/ui the uri need to be deleted and the subsequent connections now which will be
https://app.example.com:9887 or https://app.example.com:7889
should go to the same pool. The below is what I have so far…
when HTTP_REQUEST
  set host [string tolower [HTTP::host]]
  set uri [string tolower [HTTP::uri]]
  switch -glob $host
    "app.example.com"
        if { $uri starts_with "/apple/ui" } {
          [string map -nocase {"/apple/ui" ""} [HTTP::uri]]
          pool apple_9887_pool
        elseif  $uri starts_with "/android/ui" } {
          [string map -nocase {"/android/ui" ""} [HTTP::uri]]
          pool andriod_7889_pool
        else {
          pool apple_andriod_default_pool
apple_andriod_default_pool has both the pool members with 9887 and 7889 port.
Is this the right way to approach this?
Just trying to figure out what you mean: Have you got virtual servers set up for https://app.example.com:9887 and https://app.example.com:7889?
Don’t see any issue with iRule except line no 13. Missed
after elseif.
elseif { $uri starts_with "/android/ui" } {
You can’t set an empty value in URI.
You must be sure it always starts with a /
HTTP::uri [string map -nocase {"/android/ui/" "/" "/android/ui" "/"} [HTTP::uri]]
f5_rock yes I missed that…while copying.Thank you.
try this code:
when CLIENT_ACCEPTED {
  set inject_cookie 0
  set site_mode "default"
  switch -glob $host {
    "app.example.com" {
        HTTP::uri [string map -nocase {"/apple/ui/" "/" "/apple/ui" "/"} [HTTP::uri]]
        set inject_cookie 1
        set site_mode "apple"
      } elseif  { $uri starts_with "/android/ui" } {
        set inject_cookie 1
        set site_mode "android"
      } elseif {[HTTP::cookie exists site_mode]}{
        set site_mode [HTTP::cookie value site_mode]
      switch $site_mode {
        "apple" {pool apple_9887_pool}
        "android" {pool andriod_7889_pool}
        "default" {pool apple_andriod_default_pool}
when HTTP_RESPONSE {
  if {$inject_cookie} {
    switch $site_mode {
      "apple" {
        HTTP::cookie remove site_mode
        HTTP::cookie insert name site_mode value apple path "/"
        HTTP::cookie expires site_mode 300 relative
        HTTP::cookie secure site_mode enable
        set inject_cookie 0
      "android" {
        HTTP::cookie insert name site_mode value android path "/"
        set inject_cookie 0
      "default" {
        HTTP::cookie insert name site_mode value deleted path "/"
        HTTP::cookie expires site_mode 0 absolute
        set inject_cookie 0
