Customer-driven Site Deployment Using AWS and F5 Distributed Cloud Terraform Modules
Introduction and Problem Scope
F5 Distributed Cloud Mesh’s Secure Networking provides connectivity and security services for your applications running on the Edge, Private Clouds, or Public Clouds. This simplifies the deployment and configuration of connectivity and security services for your Multi-Cloud and Edge Cloud deployment needs across heterogeneous environments.
F5 Distributed Cloud Services leverages the “Site” construct to deploy our Secure Mesh or AppStack Site instances to manage workloads. A Site could be a customer location like AWS, Azure, GCP (Google Cloud Platform), private cloud, or an edge site. To run F5 Distributed Cloud Services, the site needs to be deployed with one or more instances of F5 Distributed Cloud Node, a software appliance that is managed by F5 Distributed Cloud Console. This site is where customer applications and F5 Distributed Cloud services are running.
To deploy a Node, different options are available:
Customer deployment topology description
We will explain the above steps in the context of a greenfield deployment, the Terraform scripts of which are available here. The corresponding logical topology view of this deployment is shown in Fig.2.
This deployment scenario instantiates the following resources:
  • Single-node CE cluster
  • AWS SLO interface
  • AWS VPC
  • AWS SLO interface subnet
  • AWS route tables
  • AWS Internet Gateway
  • Assign AWS EIP to SLO
The objective of this deployment is to create a Site with a single CE node in a new VPC for the provided AWS region and availability zone. The CE will be created as an AWS EC2 instance. An AWS subnet is created within the VPC. CE Site Local Outside (SLO) interface will be attached to VPC subnet and the created EC2 instance. SLO is a logical interface of a site (CE node) through which reachability is achieved to external (e.g. Internet or other services outside the public cloud site). To enable reachability to the Internet, the default route of the CE node will point to the AWS Internet gateway. Also, the SLO will be configured with an AWS External IP address (Elastic IP).
Fig.2. Customer Deployment Topology in AWS
List of terraform input parameters provided in vars file
Parameters must be customized to adapt to the customer environment. The definition of the parameters in the “terraform.tfvars” show in below table.
Parameters  Definitions
owner Identifies the email of the IT manager used to authenticate to the AWS system
project_prefix Prefix that will be used to identify the resource objects in AWS and XC.
project_suffix The suffix that will be used to identify the site’s resources in AWS and XC
ssh_public_key_file Local file system’s path to ssh public key file
f5xc_tenant Full F5XC tenant name
f5xc_api_url F5XC API url
f5xc_cluster_name Name of the Cluster
f5xc_api_p12_file Local file system path to api_cert_file (downloaded from XC Console)
aws_region AWS region for the XC Site
aws_existing_vpc_id Existing VPC ID (brownfield)
aws_vpc_cidr_block    CIDR Block of the VPC
aws_availability_zone AWS Availability Zone (a)
aws_vpc_slo_subnet_node0 AWS Subnet in the VPC for the SLO subnet
Configuring other environmental variables
Export the following environment variables in the working shell, setting it to customer’s deployment context.
Environment Variables Definitions
AWS_ACCESS_KEY AWS Access key for authentication
AWS_SECRET_ACCESS_KEY AWS Secret key for authentication
VES_P12_PASSWORD XC P12 Password from Console
TF_VAR_f5xc_api_p12_cert_password Same as VES_P12_PASSWORD
Deploy Topology
Deploy the topology with:
  • terraform init
  • terraform plan
  • terraform deploy –auto-approve
And monitor the status of the Sites on the F5 Distributed Cloud Services Console.
Created site object will be available in Secure Mesh Site section of the F5 Distributed Cloud Services Console.
Video-based description of the deployment Scenario
This demonstration video shows the procedure for provisioning the deployment topology described above in three steps.
References
