Any idea how I can create an SSL CSR (preferably from the GUI) in v11.x? is this the only option 404 Page not found | BIG-IP Documentation ?
Thanks!
Thanks!
Go to System - File Management - SSL Certificate List tab, and click the Create button. Select “Certificate Authority” from the drop down, fill in all of the required values and submit. The next page will allow you to download the resulting CSR.
Thanks very much Kevin. That did it.
