Where is the location of CSR at F5 CLI. I would like to see the location and command to find a CSR from F5 CLI
@f5Subrun It depends on which CSR you’re looking for. Is this for the device SSL cert in the GUI or is this for SSL certs for terminating HTTPS on the F5?
CSR Directory:
cd /config/ssl/ssl.csr/
Follow the article to how to manage the certs
HI,
try the command - tmsh show /config/bigconfig/ssl.csr/
BR
Aswin
Hi f5Suburn,
In BASH Mode Try following
tmsh list sys crypto cert all
tmsh list sys crypto csr
to list all the cert/key/csr etc etc for all the partitions recursively use the following master command id more partitions other than /Common
tmsh -q -c "cd / ; list sys crypto recursive all-properties "
In TMSH Mode try following
if only one partition or you want to run on individual partition use this in TMS Mode
list sys crypto crl
list sys crypto csr
list sys crypto key
show sys crypto
Very Limited output
root@(Test-Box1-Active)(cfg-sync In Sync)(/S1-green-P::Standby)(/Common)(tmos)# show sys crypto
15 certificates found
0 certificate revocation lists found
3 CSRs found
9 keys found
FIPS 140 is not licensed.
Sys::Crypto Acceleration Distribution:
Primitive Forced CPU Total
ECDH 14 14
ECDSA Sign 0 0
RSA encrypt/verify 0 28
Sys::Encrypted Attributes
Object Type Object Name Attribute Valid Encryption
profile_serverssl ****SCRUBBED-DUE-TO_PRIVACY****.com-serverssl passphrase 1
profile_sctp sctp secret 1
profile_clientssl ****SCRUBBED-DUE-TO_PRIVACY****.com passphrase 1
profile_clientssl ****SCRUBBED-DUE-TO_PRIVACY****.com-clientssl passphrase 1
clientssl_certkeychain ****SCRUBBED-DUE-TO_PRIVACY****.com-clientssl 2023-CER-****SCRUBBED-DUE-TO_PRIVACY****_Private_CA_2022_0 passphrase 1
clientssl_certkeychain ****SCRUBBED-DUE-TO_PRIVACY****.com 2016-CER-****SCRUBBED-DUE-TO_PRIVACY****.com passphrase 1
auth_tacacs_config system-auth secret 1
app_cloud_security_service f5-credential-stuffing-cloud-app access_token 1
app_cloud_security_service f5-global-cloud-app access_token 1
Sys::Master-Key
master-key hash <****SCRUBBED-DUE-TO_PRIVACY****==>
previous hash <****SCRUBBED-DUE-TO_PRIVACY****==>
For CLI Path to CSR folder use cd command and use TAB for autocomplete in case if you are not sure of
root@(Test-Box1-Active)(cfg-sync In Sync)(/S1-green-P::Standby)(/Common)(tmos)# bash
[root@Test-Box1-Active:/S1-green-P::Standby:In Sync] ~ # cd /config/s
snmp/ ssh/ ssl/ startup statsd.conf
[root@Test-Box1-Active:/S1-green-P::Standby:In Sync] ~ # cd /config/ssl/
.f5km-lastlog ssl.crl/ ssl.crt/ ssl.csr/ ssl.key/
[root@Test-Box1-Active:/S1-green-P::Standby:In Sync] ~ # cd /config/ssl/ssl.csr/
[root@Test-Box1-Active:/S1-green-P::Standby:In Sync] ssl.csr # ls
2015-***-****.***.com.csr
[root@Test-Box1-Active:/S1-green-P::Standby:In Sync] ssl.csr # ls -la
total 12
drwxr-xr-x. 2 root root 4096 Nov 4 14:03 .
drwxr-xr-x. 6 root root 4096 Oct 9 18:51 ..
-rw-r--r--. 1 root root 1541 Dec 11 2015 2015-***-****.***.com.csr
To read the content of the csr file either use list command or to read the file use cat command.
TestAdmin1@(Test-Box1-Active)(cfg-sync In Sync)(/S2-green-P::Active)(/DEV)(tmos)# list sys crypto
Options:
all-properties current-module non-default-properties one-line recursive |
Modules:
cert-validator fips
Components:
acceleration-strategy allow-key-export ca-bundle-manager cert cert-order-manager client crl csr key server
TestAdmin1@(Test-Box1-Active)(cfg-sync In Sync)(/S2-green-P::Active)(/DEV)(tmos)# list sys crypto cert
Modules:
cert-validator
Components:
Options:
all |
Properties:
app-service fingerprint {
Configuration Items:
2022-CER-******************** 2023-CER-*************.com
TestAdmin1@(Test-Box1-Active)(cfg-sync In Sync)(/S2-green-P::Active)(/DEV)(tmos)# list sys crypto cert ?
Options:
all Apply the command to all configuration items
| Route command output to a filter
Identifier:
[object identifier] Certificate name/identifier
Properties:
“{” Optional delimiter
app-service
fingerprint Displays the SHA-256 fingerprint of the certificate.
TestAdmin1@(Test-Box1-Active)(cfg-sync In Sync)(/S2-green-P::Active)(/Common)(tmos)# list sys crypto
Options:
Modules:
cert-validator fips
Components:
TestAdmin1@(Test-Box1-Active)(cfg-sync In Sync)(/S2-green-P::Active)(/Common)(tmos)# list sys crypto all-properties
Output has been Omitted due to Privacy reason
for GUI I always use to connect my f5 boxes using WINSCP
When you select in WinSCP protocol SCP, you are not able to list folder content. This is cause because by default, you have access to TMSH and not to bash.
Recommended Actions
Reconfiguration of WinSCP.
1) Save your session in WinSCP
2) In Edit → Advanced → “Environment → SCP/Shell” → in shell field - manually put only “bash” command (do not select “/bin/bash”)
3) Save profile
Additional Information
Access to list files via WinSCP and SCP protocol require using Administrator Role user (user need to be able to jump from tmos to bash when is connected via SSH).
Kindly rate if it helps.
F5 Design Engineer
@f5Subrun - if any of these helped solve your issue please select Mark As Solution to help others find good answers. Thanks.
