I use the F5 Bigip LTM to create CSR’s and Keys. I submit the CSR to our public CA to obtain the Certificate and then import the generated certificate to the F5. I use the F5 Certificate Management GUI as a database for all of our Public Certificates (as they are all in use in our SSL profiles).
All this is good, however after 13 months when it is time to renew the certificate, I use the F5 GUI to renew the CSR. The problem is that the GUI does not allow me to create a new key when using the “Renew” option.
I could use other command line tools for this, but it would be easier to manage in the F5 GUI. Does anyone know if there is a way to renew a certificate from the F5 GUI and have it create a new Key?
For example click on “System / Certificate Management”. Then click on a Public CA Certificate and click “Renew”. Fill out the required fields and have it generate a new key.
Any advice is appreciated.
