Configuration limits for Big-IP LTM objects
are there known limits (maximum number) of configurable VIPs, POOLs and NODEs?
richard
there is no real limit. I have already deployed more than 1200 vs with all the objects that go with in this case pool node … the problem I had was latency at the GUI and synchronization that take more than 10 minutes. And more important point, it’s depending your ressource (VE ressource / hardware) that can manage all this objects…
Response from f5:
There is no limitation built into the software, because the software is meant to handle various hardware and even future hardware. You can add as much as your hardware can handle.
For more info: DevCentral - An F5 Technical Community
regards
