conditional stream irule
Currently the following irule is successful for some of the applications but breaks others:
when HTTP_REQUEST { Disable the stream filter for client requests STREAM::disable Disable compression HTTP::header remove “Accept-Encoding” }
when HTTP_RESPONSE { if {[HTTP::host] contains “connect-q.abbvie.net” } { if {[HTTP::uri] contains “layouts/15/LstSetng.aspx”} { Disable the stream filter for server responses STREAM::disable Enable the stream filter for text responses only if {[HTTP::header value Content-Type] contains “text”}{ Replace ‘old_text’ with ‘new_text’ STREAM::expression {@[Hh][[Tt][Tt](/|&.x2f;){2}@} Enable the stream filter for this response only STREAM::enable } } } }
I was wondering if someone would be able to provide the syntax such that if the uri contains “/lstsetng.aspx” then perform the stream rewrite otherwise do not perform the stream rewrite.
Thanks,
Try this. It should help out. Can’t test it at the moment to verify, but I think it’ll work.
    STREAM::disable
     Disable compression
    HTTP::header remove "Accept-Encoding"
     set variables here because you can't access these in HTTP_RESPONSE
    set hostLower [string tolower [HTTP::host]]
    set pathLower [string tolower [HTTP::path]]
     The PATH is the URI without the query string part
    if { ($hostLower contains "connect-q.abbvie.net") && ($pathLower contains "/lstsetng.aspx")} {
        if {[HTTP::header value Content-Type] contains "text"}{
             Replace 'old_text' with 'new_text'
            STREAM::expression {@[Hh][[Tt][Tt]Pp(/|&.x2f;){2}@}
            STREAM::enable
Thanks for the response. I will give it a try and reply with results.
