Conditional Irule
I am new to irules and I need some assistance on writing an irule that will allow my local subnets to a uri that contains a specific string but will drop all external connections and also send a response code 403 to these dropped connections.
Data group defined “internal_subnets”
string in uri “?arch” on which rule is to apply.
Any assiatance would be greatly appreaciated.
JB
if { not (class match [IP::client_addr] equals internal_subnets) and ([URI::query [HTTP::uri]] contains “arch”) } {
HTTP::respond 403 content “Forbidden”
Hi Sashi,
this is exactly the function I was looking for but I get a syntax error when I create the irule, I am on version 9.4.6, I have tried adding the $:: but without success.
01070151:3: Rule [jbtest] error:
line 2: [parse error: PARSE syntax 36 {syntax error in expression " not (class match [IP::client_addr] equals internal_subnets)…": variable references require preceding $}] [{ not (class match [IP::client_addr] equals internal_subnets) and ([URI::query [HTTP::uri]] contains “arch”) }]
JB
ok, u cant use class on v9. use matchclass instead
Hi JB,
What Sashi told you should work fine, but if you wanted to change the order of things you could save yourself a few cycles by not doing an IP Address compare and a Query inspection for every request.
You could search for the Query Value and if it matches then do the IP Address lookup.
v10.x.xwhen HTTP_REQUEST {
if { [HTTP::query] contains "arch" } {
if { !([class match [IP::client_addr] equals internal_subnets]) } {
HTTP::respond 403 content "Forbidden"
} v9.x.xwhen HTTP_REQUEST {if { [HTTP::query] contains "arch" } {if { !([matchclass [IP::client_addr] equals $::internal_subnets]) } {HTTP::respond 403 content "Forbidden"}}}
Just another option.
Hope this helps.
Thank You, I will test both of these options out tonight and update tomorrow.
Sashi and Michael,
This rule works as desired!
Thank you both for the assitance.
JB
